So I was looking at the BitFenix spectre pro 200mm fans and decided to look if they fit my 780T case on the internet. I saw where and how 140mm fans and 120mm fans fit but nothing on 200mm but it said on a guide that it would fit. Can anyone explain please?
https://linustechtips.com/topic/341965-does-it-fit/
See the fan mount locations here: http://www.corsair.com/en-us/graphite-series-780t-white-full-tower-pc-case
Short answer, no, apparently not.
CPU i7-9700K @ 5 GHz Motherboard ASUS ROG Strix Z390-F RAM Corsair Vengeance 32 GB (4x8) 3000 MHz GPU ASUS RTX 2080 ROG Strix OC x2 SLI Case Corsair Graphite 780T Storage 256 GB Samsung 860 EVO, 6 TB Seagate Barracuda PSU Corsair HX1200i, 1200W Display(s) ASUS PG279Q (1440p 165 Hz), ASUS VG248QE (1080p 144 Hz) Cooling ASUS ROG Ryujin 360 radiator Keyboard Logitech G710+ Mouse Logitech G502 Sound Logitech G35 Operating System Windows 10
https://linustechtips.com/topic/341965-does-it-fit/#findComment-4659005
So then in what case would 200mm fans fit??
In any case that says they support 200mm fans. Just look in the case specs and they always have fan support listings
Im so patriotic, I piss red white and blue. My doctor told me it was pancreatic cancer, I told him to SHUT HIS COMMIE MOUTH.
-A shotgun wielding redneck
https://linustechtips.com/topic/341965-does-it-fit/#findComment-4659029
There're not many cases that actually support 20cm fans. Only some ricer tier ones.
Intel i7 7700K | MSI Z270 Gaming M3 | MSI GTX 1070 Gaming X| Corsair Vengeance LPX 2x8GB DDR4 3000Mhz Samsung EVO 850 250GB | WD Blue 1TB | Corsair CS650M | Thermalright Macho Rev. A | NZXT S340
CM Storm Quickfire TK [MX Blues] | Zowie FK1 |  Kingston HyperX Cloud
https://linustechtips.com/topic/341965-does-it-fit/#findComment-4659082
Aeorcool cases usually support 200mm fans.
xpredator etc
CPU i5 6600K | Mobo Gigabyte Z170X Gaming 7 | Cooling H80i | MSI GTX970 Gaming 4GB in SLi | Geil Super Luce 16GB 3000MHz DDR4 | Intel 330 120GB | 2 x 1TB WD Black | Corsair Air 540 | XFX ProSeries 1250W. | Corsair K70 Anodised Black Cherry Reds | Logitech G502 | Dell U2713HM | Red LED Lighting.
Portable Gamer - Metabox Alpha W370SS - CPU i7 4710MQ | RAM 8GB 1600MHz | Nvidia GTX 860M 2GB GDDR5 | Samsung 840 EVO 250GB SSD | 17.3" Matte Display 72% Gamut
Back-up - HP Pavilion dv6 - Ancient Stuff - P7550 @ 2.26gHz  | DDR2 4GB | Kingston HyperX 120Gb SSD | ATi 4550m (fried)
https://linustechtips.com/topic/341965-does-it-fit/#findComment-4659102
If case doesn't list the fan sizes in specs, they don't support those sizes. Furthermore, Spectre Pro and Spectre fans are bit different sizes. The frame of Pro is much wider than what normal uses. So even if case has support for 200mm fans, they may not fit. I've had this problem with my current NZXT Hades case.
E: Let me add. It will not fit by default. But nothing is preventing you from stuffing it there and modding it to stay. But still, remember to measure wideness before ripping anything out.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/341965-does-it-fit/#findComment-4665709
