"slightly" under $2000 http://au.pcpartpicker.com/p/j74wZL could upgrade the cpu to a i7 4790k if your budget allows, oh yeah and a hard drive :P
 Intel i7 4790k, Gigabyte GTX 980 G1, Kingston Hyper X fury 16GB, MSI Z97S SLI Krait, Cooler Master Hyper 212x, NZXT Noctis 450, Samsung 850 EVO 128GB + WD caviar blue 1TB, EVGA 750W G2.
https://linustechtips.com/topic/341916-next-build/#findComment-4658294
when you an already get a 980, pls get one with the sexy stock cooler, also get a Crucial mx200 250GB or Samsung 850 evo 250GB with a 1TB WD blue
https://linustechtips.com/topic/341916-next-build/#findComment-4658379
CPU Cooler: Deepcool GAMMAXX 400 66.3 CFM CPU Cooler  ($54.00 @ Mwave Australia)
Motherboard: MSI Z97-G45 Gaming ATX LGA1150 Motherboard  ($189.00 @ Umart)
Memory: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1600 Memory  ($175.98 @ Mwave Australia)
Storage: OCZ ARC 100 240GB 2.5" Solid State Drive  ($125.00 @ Centre Com)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE 3X Video Card  ($479.00 @ Centre Com)
Case: Zalman Z3 Plus ATX Mid Tower Case  ($59.00 @ Mwave Australia)
Total: $1788.98
Generated by PCPartPicker 2015-04-06 00:57 EST+1000
$2k seems to be a very generous budget. By the by, if you have air conditioning, it would go better for you. I can just imagine your PC weltering in the merciless Australian summer sun. I chose a GTX 970 because getting a second would be less hard on your wallet than a second GTX 980. The SSD is a great purchase for the price, it out performs the MX100 which is (or was) it's closest competitor. You could probably grab a second HDD and run them in RAID 0 to improve the speeds of your video editing. I chose the G45 Gaming over the Krait because the Krait, for all it's white niceness; it a lower end motherboard. The Gaming line has a better audio solution in any case. Case is great for the price, comes with 4 fans and you can fit one more 120mm fan if you so wish. That PSU is the best 750w PSU in Australia at present for the price. 16GB of RAM, why not?
https://linustechtips.com/topic/341916-next-build/#findComment-4659140
Total: $1788.98
Generated by PCPartPicker 2015-04-06 00:43 EST+1000
$2k seems to be a very generous budget. By the by, if you have air conditioning, it would go better for you. I can just imagine your PC weltering in the merciless Australian summer sun. I chose a GTX 970 because getting a second would be less hard on your wallet than a second GTX 980. The SSD is a great purchase for the price, it out performs the MX100 which is (or was) it's closest competitor. You could probably grab a second HDD and run them in RAID 0 to improve the speeds of your video editing. I chose the G45 Gaming over the Krait because the Krait, for all it's white niceness; it a lower end motherboard. The Gaming line has a better audio solution in any case. Case is great for the price, comes with 4 fans and you can fit one more 120mm fan if you so wish. That PSU is the best 750w semi-modular PSU in Australia at present. 16GB of RAM, why not?
Silverstone ST75F-GS instead, its fully modular and 80+ gold
https://linustechtips.com/topic/341916-next-build/#findComment-4659168
Hard to reccomend that, it's the same model number for two PSU's in the same line. One Enhance OEM, one Sirtec. Enhance is decent enough, both Zalman and Cooler Master have Enhance PSU's in the price range. Sirtec is a pile of shit. It's not worth the risk. Although there is an EVGA I just noticed. The 750w G2 http://au.pcpartpicker.com/part/evga-power-supply-220g20750xr Thats a Super Flower OEM, even better than Enhance. I'll edit my post and recommend that instead.
https://linustechtips.com/topic/341916-next-build/#findComment-4659221
