My friend and I had a debate, and I wanted to see what's right.
I posted a reddit link showing how much VRAM is used in popular AAA games. He disagreed with the fact that I said "VRAM used," as texture data is accumulated in the VRAM, so the "x" amount of VRAM used is "The amount of VRAM game actually needs + stored texture data from other things."
I think that VRAM stores whatever data needed for a frame, then overwrites that data for a new frame, so VRAM used is literally VRAM used in a particular application.
Who's right? That guy loves a fight so I want to get my facts straight.
My build: tis be ordered
https://linustechtips.com/topic/341874-how-does-vram-work/
VRAM works nearly the same as RAM... just for video. Frequently used files (textures), applications (frames), etc are in the VRAM and will stay there until they're no longer needed, then be marked to be freed / deleted from the VRAM when that space is needed again. The game only needs enough VRAM to store the frame buffer and textures. Higher resolution = bigger framesizes. Bigger framesizes = harder to generate (the purpose of a gpu), hence why higher res on same settings = lower fps.
https://linustechtips.com/topic/341874-how-does-vram-work/#findComment-4657851
VRAM is like RAM but it's Video-RAM, so it stores image data that the computer display. Like buffer between CPU and GPU, so the "image" is read by the CPU then worked by the VRAM then converted by RAMDAC (RAM Digital to Analog Converter).
Where I hang out: The Garage - Car Enthusiast Club
My cars: 2006 Mazda RX-8 (MT) | 2014 Mazda 6 (AT) | 2009 Honda Jazz (AT)
PC Specs
Indonesia
CPU: i5-4690 | Motherboard: MSI B85-G43 | Memory: Corsair Vengeance 2x4GB | Power Supply: Corsair CX500 | Video Card: MSI GTX 970
Storage: Kingston V300 120GB & WD Blue 1TB | Network Card: ASUS PCE-AC56 | Peripherals: Microsoft Wired 600 & Logitech G29 + Shifter
Australia
CPU: Ryzen 3 2200G | Motherboard: MSI - B450 Tomahawk | Memory: Mushkin - 8GB (1 x 8GB) | Storage: Mushkin 250GB & Western Digital - Caviar Blue 1TB
Video Card: GIGABYTE - RX 580 8GB | Case: Corsair - 100R ATX Mid Tower | Power Supply: Avolv 550W 80+ Gold
https://linustechtips.com/topic/341874-how-does-vram-work/#findComment-4657871
