PCI-E 3.0 Ribbon Cable
Go to solution Solved by Jack.EXE,
The differance is the chipsets, not the wites themselves.
Edit: Wires* Sorry, I'm on a mobile.
I want to use a PCI-E Ribbon Cable for a really special custom build after I saw Peter Brands do it in this build here:
http://forum.corsair.com/forums/showthread.php?t=115290
Specifically these pictures:
http://www.l3p.nl/files/Hardware/Parvum%20Systems%20S1.0/4-build1/3%20%5B2560pxl3p_parvum%5D.JPG
http://www.l3p.nl/files/Hardware/Parvum%20Systems%20S1.0/11-final/12%20%5b2560pxl3p%5d.JPG
I found this on eBay:
http://www.ebay.com/itm/New-PCI-Express-PCIe-PCI-E-x16-Extender-Flexible-Ribbon-Cable-/281094584069?pt=LH_DefaultDomain_0&hash=item41728af705
but it's PCI-E 1.0 and I can't seem to find anything that's 2.0 or 3.0 compliant.  Does anyone know why?  Or does anyone have a link to one?
CPU: i7 6850K RAM: 64GB 3200Mhz Mobo: EVGA Micro2 PSU: EVGA P2 850W GPU: EVGA 1080 Ti FE
Case: Fractal Design Node 804 Cooler: NH-D15S
Storage: Samsung 850 Pro 256GBSandisk Ultra II 960GB
OS: Windows 10 | Display: LG 34UM94 & Asus PG279Q
https://linustechtips.com/topic/34165-pci-e-30-ribbon-cable/
They are just wires connecting the slots, it will work fine enough.
I know what they are lol.  But why would 1.0 work well enough?  What if I'm putting a 780 in this?
https://linustechtips.com/topic/34165-pci-e-30-ribbon-cable/#findComment-437915
It's a digital signal, the wires dont make a difference (up to a certain distance) and the physical form dactor has not changed. If we were talking analog, then we'd have a problem. But it's digital, so you are fine.
So you're saying 1.0 will perform the same as 3.0...?  Inform this unscholarly man.
https://linustechtips.com/topic/34165-pci-e-30-ribbon-cable/#findComment-437941
Very cool... I really appreciate your help on this.  Thanks
https://linustechtips.com/topic/34165-pci-e-30-ribbon-cable/#findComment-437966
i never used one of those cables but it will work fine
He is the hero this forum deserves but not the one it needs right now.So we'll hunt him because he can take it because he is not our hero he is a silent guardian
a watchful protector A Dark Knight
https://linustechtips.com/topic/34165-pci-e-30-ribbon-cable/#findComment-438000
Good to hear.  I might post a build log if I ever find the time to build this thing.
https://linustechtips.com/topic/34165-pci-e-30-ribbon-cable/#findComment-438013
The difference between 1.0 and 3.0 is very very minor like a 1fps difference so there should be no worry there.
Listen if you care.
https://linustechtips.com/topic/34165-pci-e-30-ribbon-cable/#findComment-438110
