I need a new case and was thinking about this one:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146058
I preferably want a case that has a window, leds (doesnt matter what color), under $60USD.
Please give me your input on this case if you have it!  How is the cable management, etc, etc.
Please give me your input in general.
https://linustechtips.com/topic/34108-case-for-under-60usd/
I recently did a build for a friend in a sharkoon t9 case, it's right around your budget and has pretty much everything you're looking for.
http://www.sharkoon.com/?q=en/node/1858
A nice side panel, 2 fans in the front, 1 in the back and you can choose what color LEDs you want.
Setup Video -----------Peasant Crushing Specs----------- 4K Benchmarks
-CPU- i7 3930k @4.8GHz 1.4v -Mobo- Asus Rampage IV Extreme -GPUs- 2x GTX Titan Hydrocopper SLI -RAM- 32GB (8x4GB) Corsair Vengeance 1600MHz -Storage- 500GB Samsung 840 SSD | 2TB WD Green HDD
-Monitors- 3x BenQ XL2420T | 1x Dell U2713HM -Mouse- Steelseries Rival -Keyboard- Corsair K70 Cherry MX Brown -Headphones- Audio Techinca ATH-M50 -Microphone- RØDE NT1-A
https://linustechtips.com/topic/34108-case-for-under-60usd/#findComment-437212
How exactly do I choose the color or checkout.  Is there is another website that has these,like newegg, ncix, etc.?
https://linustechtips.com/topic/34108-case-for-under-60usd/#findComment-437344
NZXT Source 210 - I have a friend who owns it. The only issue is there isn't much room for aftermarket Heatsinks.
System Specs - CPU: i7 4770K - RAM: 8GB(2x4GB) Vengeance Pro - Motherboard: Maximus VI Gene - Case: Modded PowerMac G5 - CPU Cooler: H100i - PSU: AX860i - SSD: Samsung 840 Series 120GB and Kingston V300 120GB - HDD: Seagate Barracuda 1TB - Graphics Card: 2x GTX 780 - Case Fans: SP120s and Spectre 140s - Headphones: HD700, Alpha Dog, SE215
Sony A7R w/ Zeiss 55mm F1.8
https://linustechtips.com/topic/34108-case-for-under-60usd/#findComment-437357
I bought it from a Swiss store, so I'm not sure where else they sell it.
Actually i just found them on ebay, here you go: http://www.ebay.co.uk/bhp/sharkoon-case
https://linustechtips.com/topic/34108-case-for-under-60usd/#findComment-437366
that sharkkon case is pretty nice for 60$
He is the hero this forum deserves but not the one it needs right now.So we'll hunt him because he can take it because he is not our hero he is a silent guardian
a watchful protector A Dark Knight
https://linustechtips.com/topic/34108-case-for-under-60usd/#findComment-437589
Do you know if it would fit a CoolerMaster Hyper 212 Evo?
Id say the NZXT source 210
buy some bitfenix alchemy LED strips
the cable management is great for 30 bucks and it has a very nice piece of acrillic for the window, very clear.
it closely fits the hyper 212 EVO.
https://linustechtips.com/topic/34108-case-for-under-60usd/#findComment-437756
Before my R4 I had a NZXT Source 210 Elite case and worked really well and had enough room for everything.
CPU: Intel core i5 3570 Motherboard: Gigabyte-H77-DS3H Case: Fractal Design Define R4 Storage: Seagate Barracuda 2TB  GPU: MSI Radeon HD 7950 Twin Frozr III Cooler: CM Hyper 212 Evo RAM: Crucial Ballistix Sport 16GB  PSU: Seasonic G Series 550W
Acer Aspire S7 Overview Sennheiser PC360
https://linustechtips.com/topic/34108-case-for-under-60usd/#findComment-438086
This is the best case in my opinon for under $60 (http://www.newegg.com/Product/Product.aspx?Item=N82E16811163227&Tpk=rl04b&IsVirtualParent=1
) and I personally own it. It comes with dust filters, you can put a Kraken X60 in the roof, plenty of room for cable management, and removable hard drive cages.
https://linustechtips.com/topic/34108-case-for-under-60usd/#findComment-438961
It scratches the side panel, but it fits
https://linustechtips.com/topic/34108-case-for-under-60usd/#findComment-439085
I'd go for the Corsair Carbide 200R, It's a great, simplistic case that is by FAR better than any other $60~ case, from the black, textured finish to the silence and build quality it's the perfect case for my taste. Also, since it's Corsair branded you know that it will be compatible with most coolers on the market including dual 120/140 rads. I like it so much that I will try to mod in a side panel window. Instead of getting a new one.  :)
https://linustechtips.com/topic/34108-case-for-under-60usd/#findComment-439910
