Will it Case?
Go to solution Solved by SonoDanshi,
I can't help with whether those cards will fit or not, but if you want a GTX 970 and are worried about the card length then you could look at the ITX versions of the 970 from Gigabyte and Asus.
Gigabyte
http://www.amazon.com/Gigabyte-GeForce-Overclocked-GDDR5-GV-N970IXOC-4GD/dp/B00OQUMGM0/
Asus
http://www.amazon.com/Asus-GTX970-DCMOC-4GD5-ASUS-Graphics-Cards/dp/B00RL2SLAG/
Hi there!
As I am nearing my completion of having a PC all I need is a GPU. I already have the "Basics" of a Computer built. The reason why I didnt grab the GPU while buying my other parts is because I wanted to wait for prices to come down or save enough money, now I have $400.
Would any of these GTX 970's fit my Apex PC-389-C case?
1. MSI GTX 970 OC
2. MSI GTX 970 Gaming
3. Asus Strix
I can only buy a Graphics card and not buy a new case because I don't live in the US and shipping rates are high (Like $25-50).
CPU:
i5 4460
Motherboard: MSI H81M-E33
Ram: Crucial B. Sport XT 8GB DDR3 1600
PSU: EVGA 500w 80 Plus
HDD: WD 1TB
Thanks for reading! :)
https://linustechtips.com/topic/340634-will-it-case/
maybe
why such a crap case?
i5-4690k @ 4.2GHz | Asus Radeon R9 290 DirectCU II | Hyper 212 EVO | ASRock Z97 Extreme3 | Corsair Vengeance 8GB 1866MHz, Corsair XMS 4GB | 850 EVO 250GB, random 1TB drive | Corsair 200R | EVGA SuperNOVA 750W | Rosewill RK-9000BR | Logitech G700s | Logitech G930 | ViewSonic VG2427wm, Dell S2209W, Dell S2009W
Dell Inspiron 3147
Latitude E5420, Samsung 840 EVO 250gb, 12gb RAM, 1600x900 display
Pentium G3258 @ 3.2GHz | WD Red 2TB x3 in RAID-Z, Crucial MX100 128GB(cache drive) | Fractal Design Node 304 | Gigabyte GA-H97N-WIFI | Crucial Ballistix Sport 8GB | EVGA 500B
HTC One M8 64GB, Droid Razr M
https://linustechtips.com/topic/340634-will-it-case/#findComment-4643646
The money  -_-
oh, okay
Dell Inspiron 3147
https://linustechtips.com/topic/340634-will-it-case/#findComment-4643670
Gigabyte
Asus
duc sequere aut de via decede
CPU: i7 6800K | Mobo: MSI X99 Gaming Pro Carbon | GPU: SLI EVGA 980 Ti Hydro Copper | PSU: EVGA 1000P2 | Memory: 64 DDR4 Corsair Dominator Platinum | Storage: Samsung 950 Pro 512GB M.2 & Samsung 850 Evo 1TB| Case: Be Quiet! Dark Base Pro 900 | Display: Predator X34 & Dell U2715H | Cooling: Custom Loop
Custom hard line watercooled Fractal Node 202 ITX build log
https://linustechtips.com/topic/340634-will-it-case/#findComment-4643707
Gigabyte
Asus
Any performance loss between these card and the longer ones?
I don't mind if I can't OC.
https://linustechtips.com/topic/340634-will-it-case/#findComment-4643741
They are fully featured cards running the same memory/core speeds as far as I'm aware. No doubt there will be benchmarks out there somewhere but everything I've heard is that as standard they should perform identically to a full sized card.
https://linustechtips.com/topic/340634-will-it-case/#findComment-4643963
