Hey everyone, im doing a new build with some minor mods inside with green accent and black base colour. Im relatively new to the idividual cable sleeving scene so you will have to forgive my lack of knowlage.
First of all i was wondering which type/brand of cable sleeving and heatshrink. Ive heard good things about mdpc. Im looking for someone who has expeiriance with some different types of sleeving and heatshrink.
Secondly, I am going to purchase the Corsair AX860i Power Supply and I was wondering if i should just use the cables and connecters that come with it or but something else.
And last of all what tools i should get for this job.
Thanks!
https://linustechtips.com/topic/34062-cable-sleeving-help/
Check out some of Corsairs own sleeved cables, it may be helpful to you. They have three pages of options you can look through.
http://www.corsair.com/en/power-supply-units/psu-accessories-1.html?p=1
CPU - I7 4770k @ 4.3GHz GPU - EVGA Nvidia GeForce GTX 780 Motherboard - ASUS Maximus VI Extreme RAM - 16GB of Corsair Dominator Platinum @ 2133MHz  Case - Corsair 800D PSU - Corsair AX1,200i CPU Cooler - Custom Liquid CPU Cooler SSD - Samsung 840 Pro 256GB Hard Drive - Western Digital Black 1TB.
https://linustechtips.com/topic/34062-cable-sleeving-help/#findComment-436574
I considered that option but I am doin two colours and want to keep consistency.
https://linustechtips.com/topic/34062-cable-sleeving-help/#findComment-436590
I highly recoomend MDPC , their caulity is just unmatched , I just ordered my sleeving 5 minutes ago :D
edit : All you need are some sleeving wires , allot of heatshrink and some tools , a pin remover and a molex pin remover (u can made then yourself too check on youtube fot that)
6600K  |  16GB HYPERX  |  GTX1070 FE  |  Z170X-UD3  |  AIR540
Respect the past, Embrace the future.
https://linustechtips.com/topic/34062-cable-sleeving-help/#findComment-436643
Thanks for the help! Sorry but what are sleeving wires? \/_\/
https://linustechtips.com/topic/34062-cable-sleeving-help/#findComment-436684
no problem :) sleeving wires are just the sleeving it could be parracord or just 'sleeving' ....
here's an MDPC page with all their sleeving
http://en.mdpc-x.com/mdpc-sleeve/sleeve.htm
https://linustechtips.com/topic/34062-cable-sleeving-help/#findComment-436722
