6950 too hot?
Go to solution Solved by tuna1146,
i fix the problem i take apart the cooler and i saw than the fan was barely sping wiht my hand i search on youtube and i saw  that i have to clean up the fan  it was stack because of the dust when i blow all the dust the fan is spining ok and i set the fan curve using MSI Afterburner. now its working perfect and temps are 80 degrees in furemark thanks for your help
i have this gpu for 2 years but now when i play some games this card go to 95 degreees i this normal or should i woried about destroy me card. i am not so confident to take apart the cooler and clean it any solution thanks. tha gpu ran a litle above stock i have overclocking with catalist contro center.
https://linustechtips.com/topic/34043-6950-too-hot/
try blowing compressdd air on it,
i replaced the thermal paste on mine and i don t see it go above 70c.
At worst what you risk isn t the card but your hearing as that gpu would be very loud at 95c... (gpu throttle if they overheat to prevent dmg...)
Anything I write is just a comment, take is as such, there is no guarantees associated with anything I say.
ATX Portable rig (smaller than prodigy(LOL)) :  Nmedia 2800 | Gigabyte Z77x-ud3h  | Corsair HX1000 | Scythe Big Shuriken | i5 3570K  |  XFX R9 290 DoubleD | Corsair Vengeance 32GB
https://linustechtips.com/topic/34043-6950-too-hot/#findComment-436292
i return it to stock setings and now its 92 degrees but on furemark i hit 110 degrees now i think i have problem. i live in greece and the temprature outside is 40 degrees Celsius all the tempratures above are in
Celsius. i dont know if it is importan but idle temps are aproximatly 60 degrees
https://linustechtips.com/topic/34043-6950-too-hot/#findComment-436324
try to chance the thermal paste.
| CPU: INTEL i5 6600k @ 4.6Ghz @ 1.328v | Motherboard: ASUS Z170-AR | Ram: G.SKILL 2x8GB 2400Mhz | CPU Cooler : Corsair H100i V2
| GPU: GIGABYTE GTX980Ti G1 GAMING | SSD: SAMSUNG 840 EVO 250GB  Storage: WD 1TB GREEN | OS: Windows 10 Pro 64bit | PSU: FSP 650W AURUM S |
<<<<< BLK-Phant0m >>>>>
https://linustechtips.com/topic/34043-6950-too-hot/#findComment-436342
i try to hear the fun at 110 degrees but i couldn hear anythin i look gpuz and i saw that fun was spining at 25% stable is this normal because i dont want to take apart my cooler by the way its stock cooler blower from ati
Then make a fan curve using MSI Afterburner.
https://linustechtips.com/topic/34043-6950-too-hot/#findComment-436369
i set the fun at 100%  but now i dont think that fun spining at all and idle are around 70 degrees i think that fan is dead any sugestions
If you think its dead try to return it if you only bought it recently. Any other ways is to prob get a aftermarket cooler for it.
https://linustechtips.com/topic/34043-6950-too-hot/#findComment-436396
i have bought this card about 3 years ago i dont have any waranty and because its faulty i have to paid around 200 euros ist no worth it can you suggest me a good after market cooler for my card my case is enermax chacra full tower  so i dont have problem with big coolers
https://linustechtips.com/topic/34043-6950-too-hot/#findComment-436405
https://linustechtips.com/topic/34043-6950-too-hot/#findComment-436592
