Define R5 Window Panel
Go to solution Solved by itsmyjobtoknow,
its a square window
I've seen both pictures of the Define R5 with a square window, and a differently shaped windowed panel. I was just wondering which one I'd actually receive. Also, all the reviews showing the pure silence of the case are with the non-windowed one. How much less silent is the windowed version?
https://linustechtips.com/topic/340085-define-r5-window-panel/
