GPU cabling problem
Solved by -rascal-,
Wait, I don't quite understand your question.
The Thermaltake Evo Blue 650W is a modular PSU. On the PSU end, the connections should be female...since you have to connect the necessary detachable cables to it before you connect it for your graphics card, SATA devices, etc.
Are you saying you have none of the detachable cables?
If that's the situation, I'm sure you can order replacements directly from Thermaltake.
