The ECS motherboard is NOT a recommended motherboard^^ (I've heard nothing but horror stories from this brand) :/
Also, see if you can find a 80+ verified PSU and the rest is OK.
Intel i7-2600K @ 4,5GHz | EVGA GeForce GTX 780 w/EKWB Copper Waterblock | Kingston HyperX blu 16GB @ 1600 MHz | Phanteks Enthoo Primo | MSI Z77A-GD65 | CM M1000 Silent Pro | Samsung 840 Pro 128GB | BenQ XL2420T 120hz | Logitech G710+ | Razer Deathadder 2013 -
- XSPC Raystorm CPU Waterblock | XSPC RX360 Radiator | EKWB EK-FC Titan GPU Waterblock -
https://linustechtips.com/topic/33951-building-for-my-cousin/#findComment-435085
http://pcpartpicker.com/p/1eGKc
here would be my idea of a $500 build.
quick note- the athlon x4 750k is an unlocked A10-5800k with out the graphics part.
edit- here would be a more performance oriented version http://pcpartpicker.com/p/1eGVR
https://linustechtips.com/topic/33951-building-for-my-cousin/#findComment-435125
https://linustechtips.com/topic/33951-building-for-my-cousin/#findComment-435164
CPU:  Intel Core i3-3220 3.3GHz Dual-Core Processor  ($120.58 @ Amazon)
Motherboard:  ASRock H77M Micro ATX  LGA1155 Motherboard  ($75.66 @ Newegg)
Video Card:  Sapphire Radeon HD 7850 1GB Video Card  ($139.99 @ Newegg)
Case:  Cooler Master Elite 430 ATX Mid Tower Case  ($29.99 @ Newegg)
Optical Drive:  LG GH24NS95 DVD/CD Writer  ($15.98 @ Outlet PC)
Total: $519.17
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2013-07-08 23:22 EDT-0400)
https://linustechtips.com/topic/33951-building-for-my-cousin/#findComment-435182
cooler master power supplies aren't very good(V series is an exception) and western digital has a 1tb hard drive for $10 cheaper. Also look at the 7770 ghz editions a better price might be their.
Here is my tweaked version of it- http://pcpartpicker.com/p/1eHcL
https://linustechtips.com/topic/33951-building-for-my-cousin/#findComment-435255
With such a low budget I would recommend dropping it to a 4GB kit instead. A Thermaltake V3 with a powersupply and ditch the optical drive if you don't need it.
CASE+PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16811133185
Main System - 2016 13"nTB MBP 256GB
Gaming Rig - 4790K, 16GB RAM, 1080Ti
Monitor - Dell 25" U2515H
K/B & M - Ducky One TKL, Logitech MX Master & G900
Audio - JDS Labs The Element, Aktimate Mini B+, Krix Seismix 3 Mk6, Ultrasone Pro 900
https://linustechtips.com/topic/33951-building-for-my-cousin/#findComment-435274
8gb fits into the budget so I don't see why not. Also the thermaltake case+psu would be more expensive than a corsair cx430 and the antec case.
https://linustechtips.com/topic/33951-building-for-my-cousin/#findComment-435316
More mullah for teh GPU
https://linustechtips.com/topic/33951-building-for-my-cousin/#findComment-440285
Am I doing it right? :D
http://pcpartpicker.com/p/1fpY4
https://linustechtips.com/topic/33951-building-for-my-cousin/#findComment-443950
Aahahah Definity. Can see it running multiple chrome tabs!
https://linustechtips.com/topic/33951-building-for-my-cousin/#findComment-444009
