Well generally speaking motherboards shouldn't heat up too much, what CPU? what motherboard? and what are your current temps?
example my 4770k at 4.6Ghz hits about 65*c with aida64 and the motherboard sits around 30-35*c regardless of the CPU temp.....
https://linustechtips.com/topic/339492-motherboard-temps/#findComment-4628520
I will have to check my motherboard temps when I get home. But my Cpu maxes out at like 35 c.
Cpu- FX-4130 currently at 4.4ghz    and the motherboard is a http://www.newegg.com/Product/Product.aspx?Item=N82E16813128565
https://linustechtips.com/topic/339492-motherboard-temps/#findComment-4628546
CPU maxes out at 35*c? and your worried about temps?
If that's correct you have a ton of room left.
https://linustechtips.com/topic/339492-motherboard-temps/#findComment-4628596
