Ok then what do u recommend and that didn't answer which one is better
First of all they are both the same...
Secondly, ditch that ssd you can add it later. Use that money for a 970/980
Third, you only need maybe 750 watts
Intel Core i7 9700k - EVGA FTW GTX 970
https://linustechtips.com/topic/339152-build-vs-build/#findComment-4624739
They are the exact same build, none of them is better, we could make a build that is 100x better :)
You are getting 4 sticks of ram on a dual channel platform and a 1200watt PSU when a 650w-750w PSU would be plenty
https://linustechtips.com/topic/339152-build-vs-build/#findComment-4624758
They're just the same..... You actually don't need 1000W+ PSU unless you're planning to go further like Crossfire or SLI.
Where I hang out: The Garage - Car Enthusiast Club
My cars: 2006 Mazda RX-8 (MT) | 2014 Mazda 6 (AT) | 2009 Honda Jazz (AT)
PC Specs
Indonesia
CPU: i5-4690 | Motherboard: MSI B85-G43 | Memory: Corsair Vengeance 2x4GB | Power Supply: Corsair CX500 | Video Card: MSI GTX 970
Storage: Kingston V300 120GB & WD Blue 1TB | Network Card: ASUS PCE-AC56 | Peripherals: Microsoft Wired 600 & Logitech G29 + Shifter
Australia
CPU: Ryzen 3 2200G | Motherboard: MSI - B450 Tomahawk | Memory: Mushkin - 8GB (1 x 8GB) | Storage: Mushkin 250GB & Western Digital - Caviar Blue 1TB
Video Card: GIGABYTE - RX 580 8GB | Case: Corsair - 100R ATX Mid Tower | Power Supply: Avolv 550W 80+ Gold
https://linustechtips.com/topic/339152-build-vs-build/#findComment-4624765
I have a 780 I don't think such a little
Upgrade in that would change much I think but idk for sure but which one should I get for future proof and will perform amazing or if neither what else should I change if they are bad?
What is your budget? We will find what is best for you
https://linustechtips.com/topic/339152-build-vs-build/#findComment-4624783
First of all, please quote people so they get notified you replied to them.
Secondly, there is no such thing as "Future proof"
https://linustechtips.com/topic/339152-build-vs-build/#findComment-4624785
around the same price of the build I posted but probably could go higher
What's the "Max"?
PC Specs
Indonesia
Australia
https://linustechtips.com/topic/339152-build-vs-build/#findComment-4624854
Ok, the 2 builds you posted are the same, 1200W is SO overkill for that it's not even funny, you could do 4 way 980s off that. Get like a 500-600W PSU. And you said you have a GTX 780, do you plan to upgrade that in the future?
My Rig:  CPU: Core i7 4790K @4.8ghz  Motherboard: Asus Maximus Vii Hero  Ram: 4x4GB Corsair Vengeance Pro 2400mhz (Red)  Cooling: Corsair H105, 2x Corsair SP120 High Preformance Editions, Corsair AF 140 Quiet Edition  PSU: Corsair RM 850  GPU: EVGA GTX 980 SC ACX 2.0  Storage: Samsung 840 EVO 120GB, WD Blue 1TB  Case Corsair 760t (Black)  Keyboard: Razer Blackwidow Chroma  Mouse: Razer Deathadder Chroma  Headset: ATH-M50X Mic: Blue Yeti Blackout
https://linustechtips.com/topic/339152-build-vs-build/#findComment-4624922
yes but not for a little bit after I get a new build cause it's not a terrible card for right now is it?
https://linustechtips.com/topic/339152-build-vs-build/#findComment-4624927
https://linustechtips.com/topic/339152-build-vs-build/#findComment-4624929
yes but not for a little after I buy a new build but I believe the card isn't bad for now is it
https://linustechtips.com/topic/339152-build-vs-build/#findComment-4624936
