Hello everyone;
This is my first ever PC build and I have a really good idea of what I'm doing but I want a second opinion. I live in Bahrain and I'm severely limited in terms of shops and shipping but i found this site and it looks good: http://www.advantionline.com/home.php
Here are the parts I have picked out for what I think is a good PC (please suggest or correct me if you have a better build)
Case:
http://www.advantionline.com/NZXT-Technologies-H440-Mid-Tower-Chassis-Cases-Black-Red.html
Motherboard:
http://www.advantionline.com/ASUS-MAXIMUS-VII-Ranger-LGA-1150-Intel-Z97-HDMI-SATA-6Gb-s-USB-3.0-ATX-Intel-Motherboard.html
CPU:
http://www.advantionline.com/Intel-Core-i7-4790-Haswell-Quad-Core-3.6GHz-LGA-1150-84W-Desktop-Processor-Intel-HD-Graphics-4600.html
Grapics Card:
http://www.advantionline.com/ASUS-GeForce-GTX-970-Strix-OC-1253MHZ-4GB-7.0GHZ-GDDR5-2xDVI-HDMI-DisplayPort-PCI-E-Video-Card.html
RAM:
http://www.advantionline.com/Mushkin-997126R-DDR3-UDIMM-2x4GB-8GB-PC3-22400-2800MHZ-12-14-14-35-Redline-Ridgeback-1.65V.html
Hard Drive:
http://www.advantionline.com/Western-Digital-Caviar-Black-WD1002FAEX-1TB-7200-RPM-64MB-Cache-SATA-6-Gb-s-3.5-Desktop-HDD.html
Boot Drive:
http://www.advantionline.com/Samsung-850-EVO-250GB-2.5-Inch-SATA-III-Internal-SSD-MZ-75E250B-AM.html
PSU:
http://www.advantionline.com/Aerocool-KCAS-600Watts-Power-Supply.html
Fans:
http://www.advantionline.com/Corsair-Air-Series-AF120-Performance-Edition-CO-9050003-WW-120mm-High-Airflow-Case-Fan.html
http://www.advantionline.com/NZXT-Air-Flow-Series-RF-FZ140-R1-140mm-Red-LED-Case-Fan.html
I'm trying to keep a budget of around 700 BHD and won't be fussed to swap one thing for another.
I'm a bit worried with the PSU, will it be able to power everything and be able to power everything and have enough cables to plug everything into?
Also, regarding the fans; I'm planing on having 3 120mm fans as air intake mounted in the front and the 140mm in the back as an exhaust fan.
Any help would be appreciated.
Thanks!
https://linustechtips.com/topic/339020-my-first-build/
lower your motherboard to a z97, and pick up a cpu cooler with the money you saved.
also upgrade to the K version of the processor allowing you to overclock.
if you don't want to overclock throw the motherboard out and just pickup a h series board.
Current Desktop Build | 2200G | RX 580 4GB | 8GB RAM | CTRL | Logitech G Pro Wireless
Laptop | 2018 MBA 256/16GB | MX Master
https://linustechtips.com/topic/339020-my-first-build/#findComment-4623009
Thanks for the suggestion. Also, I don't plan on overclocking at all because I don't know how. I heard that you can use a stock cooler if you don't overclock (I could be wrong).
I'm also not sure what an H series board is, if you can find one on the site I linked I'd appreciate it.
https://linustechtips.com/topic/339020-my-first-build/#findComment-4623096
