Bottle neck or not?
Go to solution Solved by DrShiba,
Sure you can. If you upgrade your CPU, that'd be a lot better. Also consider buying an SSD, because the HDD will always be a bottleneck imho.
Processor = Intel g3258 (planning to upgrade to i5 4670k or 4690k)
Mobo = msi z97 gaming 5
Ram = corsair vengeance 8gb 1866 (2x4gb)
HDD = WD caviar black 1tb
Case = aerocool gt-a
PSU = corsair cx750m
GPU = Evga gtx 760 2gb w/acx
Coz i already bought them. Those parts were very expensive here in the philippines. And i bought them in the US (cpu case and psu from PH)
What do you think guys? can i play 2014-2015 games using this build? Sorry newbie here.
https://linustechtips.com/topic/338782-bottle-neck-or-not/
In 1080p, yes. Only if you don't mind turning down the settings a bit in demanding titles.
| CPU: i7 4790k @ 4 Ghz | CPU cooler: H100i | Motherboard: MSI Z97-G45 Gaming | GPU: MSI GTX 970 | RAM: 16GB Kingston HyperX Beast @1866 Mhz SSD: Samsung 840 EVO 120gb | HDD: Western Digital Blue 1 TB | PSU: CX750M | Case: CM 690 III window. | LED lighting: NZXT HU| Speakers: Logitech Z623
https://linustechtips.com/topic/338782-bottle-neck-or-not/#findComment-4619504
Yup. 1080p is enough for me. But based on gamedebate site i cant play dying light? I really wanted to that game.
Btw heres the major games that i'm planning to play.
GtaV
Dying light
Crysis 3
(Maybe BF series, haven't tried any of BF games)
And dota2.
https://linustechtips.com/topic/338782-bottle-neck-or-not/#findComment-4619595
Does SSD and HDD really matter? Maybe i do have a plan of buying one. But my idea was to use it only for my OS then the other stuffs would be at the HDD
https://linustechtips.com/topic/338782-bottle-neck-or-not/#findComment-4619606
Yes, SSD is a lot faster than HDD. SSD for your operating system and some programs that you use frequently. HDD should be used for everything else.
https://linustechtips.com/topic/338782-bottle-neck-or-not/#findComment-4619642
So what does SSD really do? I dont have any idea. I've seen some vids on youtube but those comparison are just for boot time(which i really dont care, as long as it does take too much time like the windows updates. LOL) does it affect the gaming performance of the pc?
https://linustechtips.com/topic/338782-bottle-neck-or-not/#findComment-4619757
SSD makes your Windows run faster. It won't really affect the gaming performance, but loading maps in FPS or other types of games will be a lot faster.
https://linustechtips.com/topic/338782-bottle-neck-or-not/#findComment-4619771
I see. So do you recommend any SSD for OS? Maybe below $100 and btw i really dont trust PNY brand. Just my opinion thou.
https://linustechtips.com/topic/338782-bottle-neck-or-not/#findComment-4619804
