Hi guys im new to the pc WORLD and I have a build i made.  I only have two concerns with it.  the first one is, is the build good for a newer pc gamer.  im only new to pc gaming butt im a "retired" counsel gamer and im looking for a build that can do the same or better.  the second one is with my part list is there anything i can change and or upgrade.  and finally i would like to keep it as close to $1200 (not including tax) as possibly.  im really looking follower to the help and your input.
Here is the list!
http://pcpartpicker.com/p/sBrrXL
https://linustechtips.com/topic/337781-first-build/
Hi @WintersKatana just wanted to let you know you should follow your thread.
Nevertheless I think the build is pretty solid. But you have to have a Z97 board to be compatible with your Devil's Canyon CPU. You might want to also step up to a 750W PSU to be sure you have enough power. You should have enough with 600W but just to be sure and to allow for upgradability.
Hope this helps and welcome to the PC community :D
Dual Boot Windows & Hackintosh
CPU: Intel 4790K | Motherboard: ASUS Maximus Hero Vii | GPU: Zotac AMP! Extreme GTX 970 | Display: ASUS PB278Q | Case: Phantom 630 | PSU: Corsair HX1000i
Canada eh?
https://linustechtips.com/topic/337781-first-build/#findComment-4606644
