Which goes thru which?
LED diagrams on the net differ from the power source (moslty batteries/usb and using a 12v adapter/charger) and the 3.5mm Jack
So I'll be using a MOLEX for power and my 3.5mm jack is colored red,yellow and white.
10401994_10205199707264059_2070082988387
i5 4690k @ 3.5Ghz | Stock Cooler :/ | ECS Gank Machine Z87H3-A2X EXTREME | Gskill RipjawsX 8GB 1600Mhz | MSI GTX 960 100th ME 2GB | Samsung 840 Evo 120GB | 1TB WD Caviar Blue | Seasonic m12ii evo 750W | Razer Modded Phantom 410
https://linustechtips.com/topic/336312-sound-reactive-led-help/
I'm not sure about the TiP 31 controller but this seems like a good tutorial.
http://www.instructables.com/id/DIY-Music-activated-LED-controller/
Another option is using a music controller to pickup sounds:
http://www.icemodz.com/#!/Music-Led-Controller-Pack/p/25610066/category=5346676
https://linustechtips.com/topic/336312-sound-reactive-led-help/#findComment-4590033
Alright, I made one of these a few years ago for an assignment, however it was a portable speaker system. For your setup you'll want to follow this diagram:d1FJwiN.png
Yes, I used paint, if you want a proper diagram I'll make you one.
If you're interested here are my crappy portable speakers here they are:
https://youtu.be/krZ9HO6O0P8
Oh yeah you might want to mirror your audio outputs using stereo mix so you can listen to it with whatever output your speakers/headphones are with this circuit, as the LED's are sensitive to the power going through your TIP chip. in other words, less volume = no light, more volume = always lights. Basically just have two outputs in your pc, not a splitter like in my picture.
Gaming PC: CPU: i7 4770k@4.2GHz w/ CM Nepton 140xl, GPU: Gigabyte 1070 @2050, RAM: ADATA XPG V1 16GB@2133MHz, Mobo: MSI Z97 Gaming 7, Case: Corsair NZXT S340.
https://linustechtips.com/topic/336312-sound-reactive-led-help/#findComment-4605812
