Surge Protector Suggestions?
Solved by d3sl91,
Yeah, that's fine.
You can find out the maximum amperage of each item and see if that is more than 15A, but I can almost guarantee it's not.
Amps = Wattage Divided by Voltage
So, that 850W PSU will max use around 7 Amps. In reality, you will probably only use 2A. (Edit: I think i am wrong, since that is what the unit provides to the system, not draws from the wall, hence the different efficiencies, but still, its pretty close).
All of those smaller items will use less than your PC.
And then your HDTV potentially could be the most power hungry, depending on the type, but all in all, i'd be suprised if you had more than 10A listed there.
