Hey guys,
I'm currently running my loop on a table. I wanted to add another rad, but the pump wont pull fluid from the res. some air bubbles will come in the res and the fluid in the tubes will move a 2 or 3mm and that's it. I redid the loop with just the old rad and same thing happens. I drained it and filled it 4 or 5 times. The pump doe make noise so its not dead. It's a laing ddc btw.
Thanks
https://linustechtips.com/topic/335746-pump-doesnt-move-water/
Hey guys,
Thanks
I think the pump is dead, or something is broken inside. Try this (if it does not void your warranty)
Open it and turn it on. See what happens, take pics and post them on here as well so people can see if it is broke or not.
CPU: i5 4670k @ 3.4GHz + Corsair H100i      GPU: Gigabyte GTX 680 SOC (+215 Core|+162 Mem)     SSD: Kingston V300 240GB (OS)      Headset: Logitech G930
Case: Cosair Vengance C70 (white)                RAM: 16GB TeamGroup Elite Black DDR3 1600MHz       HDD: 1TB WD Blue                              Mouse: Logitech G602
OS: Windows 7 Home Premium                       PSUXFX Core Edition 750w                                                Motherboard: MSI Z97-G45               Keyboard: Logitech G510
https://linustechtips.com/topic/335746-pump-doesnt-move-water/#findComment-4580358
I'd guess either not enough power, or dead pump.
https://linustechtips.com/topic/335746-pump-doesnt-move-water/#findComment-4580373
make sure you pull as many air bubbles out as you can. also, make your pump the lowest altitude item on the table, laying everything flat wont work.
it also helps to make your resv. the top component when testing, so align all items vertically in this order:
   |>resv.   >>____
  | <rad. <<|            |
   pump.   ^^__   <<__
if it's making noise, it isn't dead.
if you get enough back pressure in your line with bubbles it would keep the pump from producing suction. also, if you pump isn't pushing liquid, turn it off. running a pump dry, or under saturated is a good way to kill it.
We can't Benchmark like we used to, but we have our ways. One trick is to shove more GPUs in your computer. Like the time I needed to NV-Link, because I needed a higher HeavenBench score, so I did an SLI, which is what they called NV-Link back in the day. So, I decided to put two GPUs in my computer, which was the style at the time. Now, to add another GPU to your computer, costs a new PSU. Now in those days PSUs said OCZ on them, "Gimme 750W OCZs for an SLI" you'd say. Now where were we? Oh yeah, the important thing was that I had two GPUs in my rig, which was the style at the time! They didn't have RGB PSUs at the time, because of the war. The only thing you could get was those big green ones.
https://linustechtips.com/topic/335746-pump-doesnt-move-water/#findComment-4580383
