Currently on the build I am considering right now I am looking at corsair 450d but I really like the size of the 350d better only problem is its micro atx, are there any good atx cases with a window the size of the 350d, also I don't like partial windows I like the full square.
https://linustechtips.com/topic/335376-help-need-compact-windowed-case/
Corsair air 240?
Long story short, no. There are cases that are small-ish and have windows and ATX compatibility but generally you will be sacrificing a lot of cooling and cable management.
Your best bet would be to add a window to something like a Lian Li PC-A05FN
I am addicted to building gaming PCs but I don't have a great reason to stop...yet...
I have the NZXT S340, Black and I love it! I highly recommend it.
CPU: Intel i7 4790k  Motherboard: MSI Z97S Sli Krait Edition  RAM: 16GB Kingston Hyperx Fury (black)  GPU: Gigabyte Geforce GTX970
Case: Coolermaster Mastercase Pro 5  Storage: 1TB WD 120GB Samsung OSD  PSU: Corsair RM750  Monitor: Acer 23"
KeyboardCM Storm Quickfire TK Cherry MX Blue  OS: Windows 10     Working on hardline watercooling!  :D
By mATX mini tower standards, the 350D is huge and just as big as some ATX mid towers. Go with the NZXT S340 as others have stated - it's the same size as the 350D but it accepts ATX motherboards too. Note that you will lose 5 1/4 external drive bays.
