What is the difference between coolers ACX 2.0 and ACX 2.0+ from EVGA ?
By
Mlody
in Graphics Cards
in Graphics Cards
Solved by Blackler,
The ACX 2.0+ Has the following Improvements:
- Straight Heat Pipes for better heat dispersion
- 0 RPM / 0db mode fans for when the graphics card isn't under load / under a certain temp so it's silent (like the Strix)
- Memory MOSFET Cooling Plate
- Backplate for the PCB
If you're looking at the 970 FTW+ it also has
- 33% higher power target
- Dual BIOS switch (easy switch)
Featured Topics
jonrosalia ·
Posted in LTTStore.com Merch1 -
amir2927 ·
4
rb19 ·
Posted in Graphics Cards4 -
2
yepnew ·
Posted in New Builds and Planning2 -
TukangKopi ·
Posted in Networking2
