Phantom 630 Panel Removal
Go to solution Solved by G33k 4 L1F3,
So just pull on it? I've been doing that but I'm worried that if I apply anymore force it'll break.
Its stating to pull up a little while pulling away from the front. I wouldn't do it till it breaks, but simply follow the steps, and it should work.
The tabs might just be a bit tough, so putting a little bit of force shouldn't hurt it...
I'm currently working on assembling a new computer using an NZXT Phantom 630 case. Right now I'm trying to install the water cooler but I can't seem to remove the plastic panel for the front and top. The front panel is held in place with these plastic clips which I can't seem to push through. I've used my fingers and pliers to no avail. The manual says nothing about this an I can't find an answer anywhere on the internet. This has brought all my progress to a halt. Is there a solution on just not seeing? Help would be much appreciated.
https://linustechtips.com/topic/335148-phantom-630-panel-removal/
CPU: Pentium G3258 @ 3.2GHz || GPU:(first release,used) MSI R9 270 OC || Motherboard:MSI Z97-G45 Gaming Motherboard || RAM: 8 GB G.Skill Sniper 1600 || Monitors: Vizio 22 in Ultra slim 1080p TV || Storage: Seagate barracuda 160 GB 7200RPM,(REFURB) 1TB toshiba 7200RPM || PSU: (stripped from 2013 CAD PC)Corsair CX600 build was under $420
BE SURE TO FOLLOW YOUR THREADS! READ THIS BEFORE POSTING IN TROUBLESHOOTING!! http://linustechtips.com/main/topic/40334-read-before-asking-for-help/
^ This, it's what I think every time I rip the front panel off of my S340, I think NZXT just likes them to clamp on tight and make sure they don't fall or get damaged when being moved. :)
Senor Shiny: Main- CPU Intel i7 6700k 4.7GHz @1.42v | RAM G.Skill TridentZ CL16 3200 | GPU Asus Strix GTX 1070 (2100/2152) | Motherboard ASRock Z170 OC Formula | HDD Seagate 1TB x2 | SSD 850 EVO 120GB | CASE NZXT S340 (Black) | PSU Supernova G2 750W  | Cooling NZXT Kraken X62 w/Vardars
Secondary (Plex): CPU Intel Xeon E3-1230 v3 @1.099v | RAM Samsun Wonder 16GB CL9 1600 (sadly no oc) | GPU Asus GTX 680 4GB DCII | Motherboard ASRock H97M-Pro4 | HDDs Seagate 1TB, WD Blue 1TB, WD Blue 3TB | Case Corsair Air 240 (Black) | PSU EVGA 600B | Cooling GeminII S524
(Deceased) DangerousNotDell- CPU AMD AMD FX 8120 @4.8GHz 1.42v | GPU Asus GTX 680 4GB DCII | RAM Samsung Wonder 8GB (CL9 2133MHz 1.6v) | Motherboard Asus Crosshair V Formula-Z | Cooling EVO 212 | Case Rosewill Redbone | PSU EVGA 600B | HDD Seagate 1TB
DangerousNotDell New Parts For Main Rig Build Log, Señor Shiny  I am a beautiful person. The comments for your help. I have to be a good book. I have to be a good book. I have to be a good book.
Fixed, thanks, just needed a bit more force, didn't break. I really do wish everything had screws though.
