The x61 is top of the range and destroys high temps.
Then again the H110i GT will be a 280mm thus having higher surface area.
They are both 280mm whoops :P
Sorry, not sure which would be better :(
https://linustechtips.com/topic/334899-which-water-cooler/#findComment-4566548
I was thinking either the kraken x61 or the H110i gt for a case I think I'm getting which is a enthoo luxe which I think it's suppose to be good if neither of those are good please recommend one
Either of them will do you well.
Main PC: 4690k, LMG Edition G1 Gaming GTX 980, 16GB Hyper X Fury, Asus Z97-A, EVGA G2 850W, Crucial MX100 128GB, WD Red 1TB 2.5", Dark Rock 3
Laptop: Asus UX305 Monitor: Asus PB278Q Keyboard: Filco Majestouch 2 TKL Mouse: Corsair M65
https://linustechtips.com/topic/334899-which-water-cooler/#findComment-4566590
