Hey guys my friends helped me put together a PC but as you can see it's over my budget, can anyone help me put together something similar but more in my price range, which is around £850 give or take, if any one could help me cheapen it with out ruining the quality to much it would be greatly appreciated.
[PCPartPicker part list]http://uk.pcpartpicker.com/p/nqLy7P) / [Price breakdown by merchant](http://uk.pcpartpicker.com/p/nqLy7P/by_merchant/)(
Type|Item|Price
**CPU** | [intel Core i7-4790K 4.0GHz Quad-Core Processor](http://uk.pcpartpicker.com/part/intel-cpu-bx80646i74790k) | £239.94 @ Aria PC
**CPU Cooler** | [Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler](http://uk.pcpartpick...er-rr212e20pkr2) | £25.31 @ Aria PC
**Motherboard** | [Asus Z97-A ATX LGA1150 Motherboard](http://uk.pcpartpick...otherboard-z97a) | £115.99 @ Aria PC
**Memory** | [Corsair Vengeance 16GB (2 x 8GB) DDR3-1600 Memory](http://uk.pcpartpick...16gx3m2a1600c10) | £106.96 @ CCL Computers
**Storage** | [Crucial MX100 512GB 2.5" Solid State Drive](http://uk.pcpartpick...-ct512mx100ssd1) | £147.29 @ More Computers
**Video Card** | [MSI GeForce GTX 970 4GB Twin Frozr V Video Card](http://uk.pcpartpick...-gtx970gaming4g) | £279.98 @ Novatech
**Case** | [NZXT Phantom (White) ATX Full Tower Case](http://uk.pcpartpick...-case-phan001wt) | £94.55 @ Aria PC
**Power Supply** | [XFX XTR 550W 80+ Gold Certified Fully-Modular ATX Power Supply](http://uk.pcpartpick...pply-p1550bbefx) | £67.38 @ More Computers
**Optical Drive** | [Asus DRW-24F1ST DVD/CD Writer](http://uk.pcpartpick...drive-drw24f1st) | £17.73 @ Amazon UK
**Operating System** | [Microsoft Windows 8.1 (OEM) (64-bit)](http://uk.pcpartpick...oft-os-wn700615) | £74.34 @ Aria PC
**Wired Network Adapter** | [TP-Link TG-3468 10/100/1000 Mbps PCI-Express x1 Network Adapter](http://uk.pcpartpick...ork-card-tg3468) | £6.46 @ Aria PC
**Wireless Network Adapter** | [TP-Link TL-WDN4800 802.11a/b/g/n PCI-Express x1 Wi-Fi Adapter](http://uk.pcpartpick...-card-tlwdn4800) | £25.74 @ Scan.co.uk
**Monitor** | [benQ GL2460HM 60Hz 24.0" Monitor](http://uk.pcpartpick...onitor-gl2460hm) | £114.99 @ Amazon UK
**Keyboard** | [Cooler Master CM Storm Devastator Gaming Bundle Wired Gaming Keyboard w/Optical Mouse](http://uk.pcpartpick...-sgb3010kkmf1us) | £29.40 @ Aria PC
**Headphones** | [Creative Labs Creative Fatal1ty Headset](http://uk.pcpartpick...s-51mz0310aa005) | £35.52 @ Amazon UK
| *Prices include shipping, taxes, rebates, and discounts* |
| **Total** | **£1381.58**
| Generated by [PCPartPicker](http://pcpartpicker.com) 2015-03-24 21:01 GMT+0000 |
https://linustechtips.com/topic/334834-help-cheapen-my-build/
What are you planning on using this computer for?
Gaming, streaming, adobe suite, facebook, etc?
Best circumstances, we can take like, 200 off without making major changes. If you want it down @ 850, you'll need to make some big changes.
Updated 2021 Desktop || 3700x || Asus x570 Tuf Gaming || 32gb Predator 3200mhz || 2080s XC Ultra || MSI 1440p144hz || DT990 + HD660 || GoXLR + ifi Zen Can || Avermedia Livestreamer 513 ||
New Home Dedicated Game Server || Xeon E5 2630Lv3 || 16gb 2333mhz ddr4 ECC || 2tb Sata SSD || 8tb Nas HDD || Radeon 6450 1g display adapter ||
https://linustechtips.com/topic/334834-help-cheapen-my-build/#findComment-4565246
why do you need a wired network adapter?
that board has very good LAN, dont quote me on that because maybe thats something completely different
that case is expensive.
buy an os from g2a or ebay
go back to 8 gigs
change psu to an evga one
maybe get a r9 290
get an 4690k
you cant cut off 500 pounds without loosing performance
also buy a smaller SSD
https://linustechtips.com/topic/334834-help-cheapen-my-build/#findComment-4565249
go back to 8 gigs
maybe get a r9 290
get an 4690k
Pretty much all this stuff but also the optical drive, you don't need that
https://linustechtips.com/topic/334834-help-cheapen-my-build/#findComment-4565293
Just for gaming mate
https://linustechtips.com/topic/334834-help-cheapen-my-build/#findComment-4565702
Get rid of the wired card, Do you need wifi?
Grab your os from g2a or other not so completely legal sites.
Go for 8gb of ram
swap the i7 for an i5
Yes I'd need wifi, what's the difference between i7 and i5 and would 8gb alter the gaming experience significantly?
https://linustechtips.com/topic/334834-help-cheapen-my-build/#findComment-4565742
You won't notice the difference between an i5 and i7 in like 80% of the games.
Also 8gb of ram is plenty.
Then get rid of the wired card and keep the wifi card.
https://linustechtips.com/topic/334834-help-cheapen-my-build/#findComment-4566860
Without changing the case, this is as low as you can get it without impacting performance in any sort of tangible way. Also, the storage solution is MUCH better than what you originally linked. 512gb will be gone in days if you plan to install games.
http://uk.pcpartpicker.com/p/Wz8jCJ
https://linustechtips.com/topic/334834-help-cheapen-my-build/#findComment-4570170
