Difference between Xeon and core i-
Solved by mvitkun,
xeon's are clocked lower,support ECC memory,support dual processor configurations,consume less power than core i typically,and are available in higher core counts.
so if you want 3D it depends on the budget.
because you can get a 4 core xeon with 8 threads for the same price as an i5.
for 3D and video editing that'd be worth it.
for gaming you'd be better off going with the i5 because of the higher clock speed.
