Hey guys!
So im doing a new build soon and its going to be super budget orientated (Around £250-£300 Including everything needed for just the tower, No OS or Monitor or KB+M) and i need help picking between a few parts. Most importantly:
  • What CPU shall i get: The Pentium G3258 (It will be OC'd) or the A8-6600K (I would be using the graphics from the CPU instead of a GPU if i get this one)
  • What GPU: a R7 260 or the Integrated graphics on the A8-6600K
Also this isnt going to be a permanent build, I do plan on getting a GTX 980 and either a FX-8350 or a 4790K (depending on the system) Within 6 months as i have to save that money up. Thanks for the help! :D
https://linustechtips.com/topic/334736-i-need-some-help/
Hey guys!
3258 and a 750/740 in my opinion.
My arsenal: i7-9700k Gaming Rig, an iPhone, and Stupidity.
https://linustechtips.com/topic/334736-i-need-some-help/#findComment-4563424
Yeppers. The GT 740 is decent but the GTX 750 is much better, if it'll fit in the budget. Both are better options than the A8-6600.
Would the 740/750 be better than the R7 260?
can you afford the i3?
Unfortunately no :( But if i do with the G3258 i will have a 4790K within a year
https://linustechtips.com/topic/334736-i-need-some-help/#findComment-4563775
The GTX 750 is better than the R7 260, but I'm not sure about the GT 740. Probs a bit less than the 260.
https://linustechtips.com/topic/334736-i-need-some-help/#findComment-4563824
