Need help
Go to solution Solved by Oshino Shinobu,
3 case/sys fans and 1 CPU fans by the looks of things. You should be fine.
post-21359-0-05794400-1427236679_thumb.j
First I would like to say I have Gigabyte GA-990FXA-UD3 motherboard and I was wondering how many case fans can I plug into this motherboard. My case comes with 3 fans and I want to make sure it will work.
Accoding to the gigabyte website it has 1 cpu fan header, 2 system fan headers and 1 other fan header.
Also follow the topics that you start so you get notifications.
CPU intel potato2 | Motherboard xpotato69 | RAM DDRPotato | GPU potato 6969 Ti | Case potato curbiide | Storage WD potato GB grey | PSU lakesonic 69 potato Watts | Display(s)69" 0.5K potato 69*69 | Cooling 4 heatpipe fried potato | Keyboard 69 key potato switches | Mouse yukon gold potato | Sound 6.9 surround potato | Operating System OS69 potato
CPU I7 5700HQ |  RAM 8gb DDR3 | GPU GTX 960M | Storage 1 TB HGST HDD | Display 15.6" 1080p IPS panel | Keyboard Steelseries RGB | Operating System Windows 10
CPU R7 3800x |  RAM 32 GB 3200MHZ DDR4| GPU RX 5700XT Ref. | Storage 1TB m.2 NVME, 2x 500GB SSD, 4TB and 750gb hdd | Display LG 32GK850F-BKeyboard Aorus K7 with reds | PSU Corsair RM750X | Case Corsair 275R | Operating System Windows 10
https://linustechtips.com/topic/334532-need-help/#findComment-4557462
