Hola!
Just joined LinusTechTips forums, thought about sharing my build, which was created in the beginning of this year :)
Specs:
Case: Bitfenix Shinobi (ATX, no side-window)
Motherboard: Gigabyte H81-D3 /ATX
CPU: Intel Pentium G3460 @ 3.5GHz
CPU Cooler: Cooler Master Evo 212
RAM: 1x4GB Corsair Vengance @ 1600MHz / CL9 [Will be upgraded]
GPU: EVGA Geforce GTX 750 Ti Ftw /w ACX Cooling; 2GB OC
HDD: WD Blue 500GB
PSU: Corsair CX430
Price tag: ~530€ish
Next upgrades?
[ ] CPU
[ ] RAM
[ ] HDD
Quick Question!
Does anyone know where I could get rubber cable management pieces (Look at the pictures, holes which cables run through in case)
post-211012-0-29996100-1427229365_thumb.
post-211012-0-58881900-1427229374_thumb.
https://linustechtips.com/topic/334436-cheaahs-corner/
Nice build but did you OC the cpu?
Nope, that CPU is locked, he was just stating the clock speed I think :)
To OP: I'd probably upgrade the CPU next IMO
Specs: CPU: AMD FX 6300 Motherboard: Gigabyte 970A DS3P RAM: HyperX Fury 16GB 1866MHz GPU: MSI R9 270 OC edition Case: Sharkoon VS3-S SSD: Samsung 840 EVO 120GB HDD: 1TB Caviar Blue PSU: Corsair CX500W
*If I say something that seems offensive, please don't take it seriously, it was most likely meant as a joke/sarcastically*
https://linustechtips.com/topic/334436-cheaahs-corner/#findComment-4554115
Nah, due to fact, that all OC possibilities from motherboard (under Z) are closed I'm not going to clock it.
Need to get that 4GB ram stick before, it's fast right now, but need it for photoshop & Sony Vegas to boost it up :)
https://linustechtips.com/topic/334436-cheaahs-corner/#findComment-4554286
