Hi,
If you have more then 1 monitor should you always set:
Multi-display/mixed-GPU acceleration: Single display performance mode or multiple display performance mode?
Ive always noticed that setting, and never could understand why it defaults to "multiple monitor performance mode"...
I always let it do its thing, as it dosent seem like it will make much impact, but just try out the different settings and see if you notice a difference.
I cant recall changing that setting when i was running 3 monitors, and it seemed ok.
Cpu: Ryzen 2700 @ 4.0Ghz | Motherboard: Hero VI x370 | Gpu: EVGA RTX 2080 | Cooler: Custom Water loop | Ram: 16GB Trident Z 3000MHz
PSU: RM650x + Braided cables | Case:  painted Corsair c70 | Monitor: MSI 1440p 144hz VA | Drives: 500GB 850 Evo (OS)
Laptop: 2014 Razer blade 14" Desktop: http://imgur.com/AQZh2sj , http://imgur.com/ukAXerd
