So I thinking about buying an AIO for my system, because I want to have it water-cooled, no real reason, just simply the aesthetics of the tubes, :P
because of this I cannot be bothered to build a custom loop.
I was wondering how hard it would be to mod an AIO, to simply change the tubes for some clear ones, and the coolant for a coloured one?
shouldn't be too hard right?
I do like the Raijintek Triton, but the reviews have not exactly filled me with confidence.
What do you guys think?
from what I've heard most of these kits use standard fittings so hopefully wont be too difficult.
Any suggestions on ones with decent pumps/blocks?, the rad doesnt need to be huge  dual 120's will be fine.
Thanks,
Cpu : AMD Ryzen 3 1200 (3.8Ghz), Motherboard : Gigabyte AB350 Gaming 3 - RAM : 8GB DDR4 2933 Team (Vulkan) memory, GPU : MSI GTX 980 4GB Case : Antec P50, Storage : 120GB Samsung SSD, 3TB WD Blue, PSU : 530w Thermaltake SPS-530MPC, Cooling : Artic freezer Pro 7, OS : Windows 10.
https://linustechtips.com/topic/333425-modding-an-aio/
Get something from swiftech, as they are designed to be taken apart and expanded.
Build
Mobo: MSI B550 MAG Tomahawk  ||||| Ram: 32 GB GSkill Trident Z RGB ||||| CPU: Ryzen 5800X ||||| GPU: ASUS RTX 3080 TUF OC ||||| Mouse: Logitech G502 ||||| Headset: Sony WH1000XM3 ||||| Keyboard: Logitech G810 Orion Spectrum ||||| Monitors: Acer XG270HU & LG UltraGear 34GP83A-B ||||| AudioStuff: ONKYO DAC HA200 / Audio Techinca ath-ad900x / MXL TEMPO KR USB Condenser Microphone ||||| Storage: 4 TB WD Black --- 2 TB WD Red --- Toshiba 258 GB M.2  ||||| Custom Loop -  Radiators: 3x360 Rad ||||| Case: LianLi O11d XL Black ||||| PSU: Seasonic X series GOLD 1250w
Laptop: Dell XPS 15 9570 4k With a Logitech MX Master
https://linustechtips.com/topic/333425-modding-an-aio/#findComment-4525019
I would recommend doing this only on ones that can be expanded or have standard fittings, such as the triton, Fractal design coolers and swiftech coolers to name the ones I know of. You can do it with pretty much any AiO, but it's less likely to be successful in the long run.
PCs
Branwen (2015 build) - CPU: i7 4790K GPU:EVGA GTX 1070 SC PSU: XFX XTR 650W RAM: 16GB Kingston HyperX fury Motherboard: MSI Z87 MPower MAX AC SSD: Crucial MX100 256GB + Crucial MX300 1TB  Case: Silverstone RV05 Cooler: Corsair H80i V2 Displays: AOC AGON AG241QG & BenQ BL2420PT Build log: link
Netrunner (2020 build) - CPU: AMD R7 3700X GPU: EVGA GTX 1070 (from 2015 build) PSU: Corsair SF600 platinum RAM: 32GB Crucial Ballistix RGB 3600Mhz cl16 Motherboard: Gigabyte Aorus X570i pro wifi SSD: Sabrent Rocket 4.0 1TB Case: Lian Li TU150W black Cooler: Be Quiet! Dark Rock Slim
https://linustechtips.com/topic/333425-modding-an-aio/#findComment-4525234
I've got a Triton and love it!  retail reviews are all from pissed off customers that got DOA products.  soon the satisfied customers will start reviewing.  I havent had any leaks or problems and I shortened my hoses to fit my build better, I haven't expanded into graphics cooling.   Raijinteks support is out of this world too, very responsive.  Test the thing outside the case first and make sure shipping didn't damage anything.
LTT Community Standards                                               Welcome!-A quick guide for new members to LTT
Man's Machine- i7-7700k@5.0GHz / Asus M8H / GTX 1080Ti / 4x4gb Gskill 3000 CL15  / Custom loop / 240gb Intel SSD / 3tb HDD / Corsair RM1000x / Dell S2716DG
The Lady's Rig- G3258@4.4GHz(1.39v) on Hyper 212 / Gigabyte GA-B85M / gtx750 / 8gb PNY xlr8 / 500gb seagate HDD / CS 450M / Asus PB277Q
https://linustechtips.com/topic/333425-modding-an-aio/#findComment-4563427
