CPU For rendering need help!
Go to solution Solved by stconquest,
Alright, you may want to consider upgrading to z97 or h97 in the future.
Not needed...
Grab a Xeon E3-1230-V3.  It has 4 cores and 4 virtual cores and is fully compatible with the H81 motherboard.  The cost should be under $300 easily.
Heey,
Could you guys please help me pick a cpu, im a youtuber and i want a fast cpu for rendering but i just dont know what cpu i need to pick, can someone please help me???
My budget is around the 200 till 300$ mark, if tis inst possible than just say what i need in the cpu. My motherbord is a MSI H81M-P33
Thanks!
https://linustechtips.com/topic/332891-cpu-for-rendering-need-help/
Either 4690k for $240 dollar or a 4790k for $340. I would save up for a 4790k though it's a better choice for video editing.
Mainboard:ROG-STRIX-B360-G-GAMING/Cpu:I5 8400 /Gpu: Galax RTX 2070 /Ram: Corsair Vengeance 16 GB DDR4/ Storage:1TB HDD 2 Corsair SSD PSU : Corsair 550W/Cooling: Silverstone Air Cooler/ / Case : Corsair/Keyboard:Razer Chroma TKL/Mouse:Mionix Castor+Steelseries Qck Mass/Headphone:V Moda M100
Quote me if you when me to reply to something.
Heey,
Thanks!
i5 4690K or a xeon. ( This xeon could work http://pcpartpicker.com/part/intel-cpu-bx80646e31240v3just keep in mind that xeons don't come with integrated graphics, whereas most i3/i5/i7s do.)
Though it really depends on what mobo you have.
xeon 1231v3
i7 features (besides overclocking)
i5 price ($240)
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
MSI H81M-P33
MSI H81M-P33
Not needed...
Not needed...
It still would be a nice idea to upgrade in the future for upgradeability and newer features.
