I'm using sabertooth 990fx r2.0. Fx 8350 and asus strix gtx 970 and a1600x900 60hz monitor running at 700w psu. I should be able to max out far cry 4 as per the benchmarks and get atleast 50fps. But I get only 30-35.
I really don't know what the problem is. I reinstald windows..updated all my drivers..even my bios is updated.
My gpu usage shows around 60 percent while playing far cry 4. This is just not acceptable.:(
Any help would be appreciated.
https://linustechtips.com/topic/332825-low-gpu-usage-gtx-970/
Common Maxwell issue, go to the Nvidia Control panel and set prefer Max Performance.
|King Of The Lost|
Project Dark: i7 7820x 5.1GHz | X299 Dark | Trident Z 32GB 3200MHz | GTX 1080Ti Hybrid | Corsair 760t | 1TB Samsung 860 Pro | EVGA Supernova G2 850w | H110i GTX
Lava: i9 12900k 5.1GHz (Undervolted to 1.26v)| MSI z690 Pro DDR4| Dominator Platnium 32GB 3800MHz| Power Color Red Devil RX 6950 XT| Seasonic Focus Platnium 850w| NZXT Kraken Z53
Unholy Rampage: i7 5930k 4.7GHz 4.4 Ring| X99
Rampage|Ripjaws IV 16GB 2800 CL13| GTX 1080 Strix(Custom XOC Signed BIOS) | Seasonic Focus Platinum 850w |H100i v2
Revenge of 775: Pentium 641 | Biostar TPower i45| Crucial Tracer 1066 DDR2 | GTX 580 Classified Ultra | EVGA 650 BQ | Noctua NH D14
https://linustechtips.com/topic/332825-low-gpu-usage-gtx-970/#findComment-4516890
Could be that the CPU is bottlenecking the 970. At lower resolutions such as 1600x900 the games become less GPU dependent and more CPU dependent. An fx 8350 is known to bottleneck the 970 at 1080p let alone 900p. However you shouldn't be getting 30 fps. Did you check clock speeds during gaming.?
https://linustechtips.com/topic/332825-low-gpu-usage-gtx-970/#findComment-4516895
yeah my clock speeds are just fine at 1316 mhz constant ! ! I've heard that gtx 970 is optimezed for 1080p display and I've seen all the gameplays at 1080p running on gtx 970 and fx 8350 on youtube and they seem to run fine at 50-60 fps maxed out. Could my monitor resolution be the problem ?
https://linustechtips.com/topic/332825-low-gpu-usage-gtx-970/#findComment-4518749
thats wired are u sure gpu is using so much
use geforce experience it will fix the problem
yes I have..however when the optimise the game using geforce experience..the game uses DSR. My gpu usage increases as in watchdogs and I get around 45 fps average which is the expected reult due to such a high resolution.
https://linustechtips.com/topic/332825-low-gpu-usage-gtx-970/#findComment-4518772
