Been monitoring my temps with hwmonitor, and speed fan , both reading the same values. tz00 temp however says 120c, but tz01 says 27c, and all others 27c to 30c at idle.
Wondering if that tz00 temp could possibly be right. everything seems nice and cool in the case. everything is cool to the touch. not sure exactly what that temp reading actually is. any info would be appreciated..
specs;
corsair 750wat ps
asus h81m-e
i5 4460 stock cooler
gigabyte gtx770
8gb ram
https://linustechtips.com/topic/332640-new-build-temp-problems/
Motherboard sensor saying the wrong readout is normal. As long as you can physically feel the components and they aren't as hot as the read out says your fine. Kind of a phantom sensor.
Specs: Cpu: i7-4790k@4.5ghz 1.19v Cooler: H100i Motherboard: Msi z97 g55 SLI  Ram: Kingston HyperX Black 16gb 1600mhz GPU: XFX R9 290X Core Edition PSU: Corsair HX850  Case: Fractal Design Define R4 Storage: Force series 3 120gb ssd, sandisk ultra 256gb ssd, 1tb blue drive  Keyboard: Rosewill RK9100x Mouse: DeathAdder  Monitors: 3 22 inch on a triple monitor mount
https://linustechtips.com/topic/332640-new-build-temp-problems/#findComment-4514804
