What was your previous CPU?
Are you new? Please read CoC  Before posting! PLEASE SELECT 'AUTOMATIC' FOR FONT COLOR FOR US DARK THEME USERS (Only for dark shades)If you can read this, it means you need to change to NIGHT THEME (bottom left above LMG logo) Please follow your threads and Quote people when replying to them. Mark your problem as solved if answered. Don't spam, nobody likes a spammer. DO NOT QUOTE IMAGES! BE NICE!
https://linustechtips.com/topic/332509-cpu-socket-help/#findComment-4512817
@Fez760 Just read were it says "LGAxxx"
That's a laptop
https://linustechtips.com/topic/332509-cpu-socket-help/#findComment-4512820
I checked and The CPU is An Intel Pentium T7400 Dual Core Processor @ 2.16 Ghz
PGA478 then
https://linustechtips.com/topic/332509-cpu-socket-help/#findComment-4512853
in theory if i upgraded to a T8100 there would be no problems??
Yea, it should
https://linustechtips.com/topic/332509-cpu-socket-help/#findComment-4512893
No, don't do it.
They've same amount of pins but they're different sockets
www_sinaimg_62c228974053d67f0f3c59cda591
Picture doesnt work.
It depends again if the laptop's socket is a PGA478 or PPGA478 which is designed for newer cpu's
https://linustechtips.com/topic/332509-cpu-socket-help/#findComment-4512927
Reuploaded for you
Ohh, i see. So is that PGA vs PPGA?
https://linustechtips.com/topic/332509-cpu-socket-help/#findComment-4512956
mPGA478MT vs mPGA478MN
OP's is mPGA478MT (the one in the right)
The pic shows the pin-to-pin incompatibility
PS:
PGA478 is a desktop socket.
Ah okay, I feel stupid now!
https://linustechtips.com/topic/332509-cpu-socket-help/#findComment-4512980
The fastest CPU you'd get is a C2D T7600, only 133 MHz more... http://www.cpu-world.com/CPUs/Core_2/Intel-Core%202%20Duo%20Mobile%20T7600%20LF80537GF0534M%20(BX80537T7600).html
IMO it isn't worth if the actual CPU works
...unless you don't care about the thing bc iirc there's a way to pinmod merom CPU's to increase FSB frequency
the goal is to breath new life into this system i am quite fond of it and i did get i back up and running my self
https://linustechtips.com/topic/332509-cpu-socket-help/#findComment-4513034
