So I have yet another Skyrim problem. Wow, big surprise.
Anyways, My problem is this.
Right now I'm in Markath, but whenever I try to leave or fast travel out of Markarth, the game gives me an infinite load screen.
Anyone got any idea on how to fix?
If you need any more info, feel free to ask!
Someone told Luke and Linus at CES 2017 to "Unban the legend known as Jerakl" and that's about all I've got going for me. (It didn't work)
https://linustechtips.com/topic/332500-another-skyrim-problem/
No clue about that, firstly get your act together, fast travel is for peugeot drivers. Anyways I believe there are many mods out there which fix many thousands of glitches and issues. I guess another mod which could work are the mods which change the way that skyrim uses fast travel. There are also mods which increases the level of errors skyrim will take before it either crashes or infinite loops. Head over to the nexus forums(steam workshop isnt good enough) and download everything, boobs are the answer to everything.
Listen if you care.
https://linustechtips.com/topic/332500-another-skyrim-problem/#findComment-4512721
Do you have any mods installed that edit the Markarth/Skyrim world space? your load order would be helpful.
instead of fast traveling can you try
coc qasmoke
then do
coc whiterun
https://linustechtips.com/topic/332500-another-skyrim-problem/#findComment-4512729
Mang, I already got 130+ mod enabled. All from Nexus. Workshop is for plebs. Mod Organizer for life!
https://linustechtips.com/topic/332500-another-skyrim-problem/#findComment-4512735
coc qasmoke
then do
coc whiterun
I can go to qasmoke, but not whiterun.
https://linustechtips.com/topic/332500-another-skyrim-problem/#findComment-4512821
you have a mod that edits the world space. you telling me you can go to qasmoke means a world space editing mod is to blame. your full modlist will be able to tell me what is causing you the issue
https://linustechtips.com/topic/332500-another-skyrim-problem/#findComment-4512836
Shot through the heart and you're to blame, 30fps and i'll pirate your game - Bon Jovi
Take me down to the console city where the games are blurry and the frames are thirty - Guns N' Roses
Arguing with religious people is like explaining to your mother that online games can't be paused...
https://linustechtips.com/topic/332500-another-skyrim-problem/#findComment-4512839
What Fulgrim suggested worked. It loads a little slower then normal, but hey, it works! Thanks for all the help guys :)
https://linustechtips.com/topic/332500-another-skyrim-problem/#findComment-4513349
I have spent many an hour on Skyrim. And many an hour fixing mod conflicts. I have overloaded Skyrim to the point that i hit my gpu's 4GB vram limit, and killed Papyrus.
And i still refuse to play it without mods.
https://linustechtips.com/topic/332500-another-skyrim-problem/#findComment-4513549
How many is many :P? I have too. Mod Manager is life. Mine has a 3GB limit. Damn 780. I have a friend who overloaded his 4 980s.
I watched a kid at school play it with no mods (he thought the cost money and stuff like that) and was playing on easy at 30 FPS on his iGPU. Some of the things he said were pretty cringe.
I can't live without mods.
https://linustechtips.com/topic/332500-another-skyrim-problem/#findComment-4513630
