Hi,
I'm going to upgrade my current desktop one by one though, I am going to start first with the CPU case, Videocard (GTX 660TI) and Power supply. My current pc has Core 2 Quad Q6600, 9500gt, non-rated PSU 400watts and a cheap case. I thought of buying a new case since 660TI might not fit on my current case since 9500gt which is a pretty small card is only a bit away from my hard drive bays. So, What can you guys recommend for a 100$ or less than case?
https://linustechtips.com/topic/3325-chassis-under-100/
For one, don't upgrade in parts, save up and upgrade all together, especially when the 700 series and Haswell have both been on the marktet. That should drop the price of current hardware down a bit, and you should have enough saved for a full system.
Anywhoo, as for a case, I can refer you to the H100 compatibility thread, as that only lists decent cases, as well as prices. What color do you like? Do you want a window? Do you care more about performance or silence? Do you like sleek designs or bulky military designs?
https://linustechtips.com/topic/3325-chassis-under-100/#findComment-42265
