Run memtest, update the bios with a usb stick, and see if that fixes it.
Also do you have a gpu?
Workstation: 3930k @ 4.3GHz under an H100 - 4x8GB ram - infiniband HCA  - xonar essence stx - gtx 680 - sabretooth x79 - corsair C70 Server: i7 3770k (don't ask) - lsi-9260-4i used as an HBA - 6x3TB WD red (raidz2) - crucia m4's (60gb (ZIL, L2ARC), 120gb (OS)) - 4X8GB ram - infiniband HCA - define mini  Goodies: Røde podcaster w/ boom & shock mount - 3x1080p ips panels (NEC monitors for life) - k90 - g9x - sp2500's - HD598's - kvm switch
ZFS tutorial
It was it's first boot. I can't run memtest as it doesn't even boot.
And I'm getting a 770 next week
hmm well that was a stupid recommendation by me wasn't it, sorry  :unsure:
At least try updating the bios, then try with just one stick of ram, then the other, and if you have other memory that you know works, try that.
ZFS tutorial
if you dont have a gpu installed and only onboard for now. try unplugging the power from the wall and take out the cmos battery for a couple mins and put it back in. plug it back in to the wall and try to boot to bios. let me know if this worked
Well I get post code 55 when I take out the ram. I might take out the CMOS battery for a few.
