So far the only experienced I've had with water cooling is with the H100i AIO. I don't even think that's anything near custom water loops because it's a plug and play kind of thing. I am here today asking for your guys opinion on what i should get for my next build (my first build was with the h100i and i built that for my older brother..). This build will be for me and will be used daily with daily game play of cs:go and occasionally triple A game with heavy graphics set to max. This build will also be under heavy load from CAD software as I also like to poke my head around in the CGI scene.
So here is the opinion i need. For this build http://pcpartpicker.com/p/R97WCJ what custom water cooling loop should i get for both the cpu and gpus?
If i should get that, what reservoir should i get and what kind of tubing?
If death has no cost, life has no worth
The dead are gone, the living are hungry
Life is not about finding yourself, it's about creating yourself.
https://linustechtips.com/topic/332207-water-cooling-options/
Water cooling will be good for this build. But, wc is never necessary.
Remember, that u'll have to do maintenance, if it doesn't scary u - do it.
If u don't know where to start, check out some ekwb ready kits. Also, reading this thread will make it easier.
https://linustechtips.com/topic/332207-water-cooling-options/#findComment-4509286
