now, i'm building a new gaming pc later this June (specs below), and I live in Israel. I need a recommendation for a cheap fan, that i can buy to get extra air flow in my 200R.
this is where i will be buying: http://goo.gl/gvQ1y3
now, I want to get more airflow, but do you think i NEED the extra fans (because i do want my components to last long)
specs:
Intel Core i5 4690k (or newer equivalent broadwell CPU if launched)
Noctua NH-D14 with default fans
8GB of G.Skill memory
Gigabyte z97x-SLI
MSI GeForce GTX 970 Gaming 4G (OR newer AMD 300 series card - probably r9 380/380x)
Corsair Force LS 120GB SSD
SeaGate Barracuda 2TB HDD
Corsair 200R
SeaSonic M12II EVO 750w
Quote me if you want to say something. Only way i'll see something.
https://linustechtips.com/topic/331678-recommendation-for-a-fan/
whatever gives the best performance and noise for the money (bang for the buck type of deal). 2 fans will be great.
Then I suggest a better case and you won't need to buy extra fans because the case will have such a good airflow and good stock coolers that they will be just enough
Longboarders/ skaters message me!
https://linustechtips.com/topic/331678-recommendation-for-a-fan/#findComment-4503191
does it HAVE to be that and ONLY that site that you provided? Because I would recommend fans from be quiet but they don't have it
as i said, i do live in israel so this is my only option.
anyway, a pair of AF/SP120's will cost around 100 NIS.
this is the link for the case site: http://en.ksp.co.il/?select=1041..130.
what case do you recommend instead of the 200R that will get me 2 more fans, that is decent quality, and has a window, because for around 380 NIS I can get the 200R and add the corsair fans.
also, i know that corsair sells strait from their website the 200R fans, that cost like 4 bucks, so I i can check if they send to here. do you recommend getting 2 of those fans?
https://linustechtips.com/topic/331678-recommendation-for-a-fan/#findComment-4503246
Shipping is probably a bit high. You could get the define r4? Or if not you can maybe get a s340 or just stick with he 200r and add those corsair fans
https://linustechtips.com/topic/331678-recommendation-for-a-fan/#findComment-4503291
i wish i could buy some fractal or NZXT stuff here. not happening. can you or anyone else look at the link i sent for the cases and look for a solid case with all the things i mentioned?
https://linustechtips.com/topic/331678-recommendation-for-a-fan/#findComment-4503309
then keep the 200r and buy extra fans if needed
https://linustechtips.com/topic/331678-recommendation-for-a-fan/#findComment-4503334
