hello i just got my r9 280x an i had a r7 250 oc and i thought it should be an upgrade but i just played CS GO and got 40-50 fps on r7 i got 100+ fps i opened up bf3 tried  all stetting even on ultra it stayed on 30-40 fps so what is the deal do i need new driver keep in mind i just got it today is the cpu a bottleneck or do i need a better PSU plz help.
https://linustechtips.com/topic/331596-r9-280x-problems-help/
That is about the performance that you will get with that card.
What are you smoking?
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
https://linustechtips.com/topic/331596-r9-280x-problems-help/#findComment-4502002
it looks to be your cpu is the bottleneck, and 8 Gb's of ram would help.
yea but i thought id be able to play my games like normal i didn't expect to get lower fps form a some what high end card but if it is can the cpu impact the prefromance so much that i get lower fps in cs go with the new card then with the old one?
https://linustechtips.com/topic/331596-r9-280x-problems-help/#findComment-4502059
yea but the thing is on my r7 i was getting 100+ but now 60-40 can the cpu do that?
I suggest that you reinstall your drivers.
In some cases, you just need to reboot your computer a few times as Windows needs to "verify" what this new card is.
For an example, just by swapping my two HD 7970's (AKA R9-280X) around (different PCI-E slots) it takes Windows some time and a reboot to have everything running smoothly.
The R9-280X requires TWO PCI-E power connections to operate properly. I doubt your 400W will have two built-in.
How are you powering your card? Are you using any Molex-to-PCI-E adapters?
Additionally, check the in-game video settings for your games. Since you upgraded to the much powerful card, the game(s) may have Auto-detected your new card and cranked the settings up. I know for a fact, BF4 will do that.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/331596-r9-280x-problems-help/#findComment-4502145
r9 280x 4 gb ram intel pentium g3220 400W PSU  my specs
Definitely the cpu. Plus, 400 watt is really cutting it close but it should be fine with your current cpu
The thing is that your r7 250 was able to run at its rated specs. If your gpu is always underclocking, it is certain that you will not get the expected performance.
Cpu:i5-4690k Gpu:r9 280x with some other things
https://linustechtips.com/topic/331596-r9-280x-problems-help/#findComment-4502156
Yes the did come in the box so i was like hey what the hell lets try it ow and the guy i bought the GPU from did say if you have a good PSU no problems and it dose say on the box 750 W or greater for 1 GPU
https://linustechtips.com/topic/331596-r9-280x-problems-help/#findComment-4502168
