I want to build a gaming rig for $1500 (including monitor)
Solved by H4X3R,
i want to plug in ethernet cable, and use the pc as a wifi router (is it possible) , to use internet in my laptop and mobiles through wifi.....
EDIT : and I forgot something, i need a dvd burner too, will sata 24x enough??
To make a wifi hotspot you will need a wifi card. A cheap one from tp link (under $20) should be adequate. As the for dvd burner, 24x is simply the maximum speed at which it can operate at, the standard being 24x so yes it is good.
i also do have a 18.5" 1366x768 monitor lying around, if i hook it up along with the 1080p monitor (dual monitor), will there be any problem??
Both monitors will run at 768p so i suggest you use displayfusion (software) to help alleviate this problem or just use 1 screen most of the time.
