To all,
       Hello, I am looking for product recommendations for shooting video services at my church. We are looking for a Video Camcorder or Camera that is able to caputre Full 1080p HD in low and bright indoor lighting. Our chruch is fully indoors with no natural outside lighting. All lighting is floresent. Video we will be taking is from the back shooting at a stage about 100 or so feet away. I would like to find something that looks clean so something that can handle 60fps if possible and doesn't look grainy. Full SD card support up to at least 128gb or more! Or a option to connect directly to PC for a live recording/online webcam type option. I am not sure if this is even possible. On a budget so the cheaper the better. Any suggestions would be appreciated. Thanks!
James Nelson
PC Hobbiest - Reviewer
Twitter - www.twitter.com/jamesnelsontnv
Youtube - www.youtube.com/NelsonGameTv
https://linustechtips.com/topic/330623-help-with-product-recommendations/
RX 100 MKIII
Best camera ever.
My Main Build: NZXT S340 - NZXT Kraken X31 - Crucial MX100 256GB - i5 4460 - Gigabyte Z97P D3 - Kingston HyperX Red 8GB - MSI Nvidia GTX 780 3GB - Corsair LL & HD RGB Fans, Corsair Lighting Node Pro.
To all,
As far as PC capture/streaming or uploading onlines goes, you could get a blackmagic (or similar) HDMI capture card fitted to the PC providing the camera you buy has clean HDMI out
Without knowing a budget its hard to really recommend anything
If you want the simplest operation, a 1080p Camcorder with HDMI out, would be your best option as they have decent easy to use zoom and good autofocus
a DSLR could be an option but it will require a bit of learning - but it will be more more flexible with better IQ
