Power Supply
I wouldn't recommend any cheap, or cheapish power supplies to be honest. It is the single most down-prioritized part of a computer, and arguably the single most important. Without a good power supply, the rest is worthless, and I have seen a lot of cheap powersupplies break, and in some cases damage the hardware connected, over the years.
Something like a Cooler Master GM-series might be within reach with only €60 to spend.
http://www.computeruniverse.net/en/products/90536754/cooler-master-gm-series.asp
And a quick google search shows that it is.
For future builds though, consider spending a bit more on the PSU, cause if you get something really good, you'll be able to keep it for years. Corsair HX(i) or AX(i) will last a decade, easily. And from that point of view, they are not that expencive either.
