using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
namespace ConsoleApplication4
    class Program
        static void Main(string[] args)
            int a = 0;
            int b = 1;
            int sum = 1;
            for (int i = 0; i < 10; i++)
                Console.WriteLine(sum);
                sum = a + b;
                a += b;
                b += sum;
            Console.ReadKey();
So i'm trying to get the fibonacci nrs up to 10 but for some reason my program skips every second number
Why
My logic is in the white .txt file and the outcome from the program is in the black one to the right.
Redliquid~
https://linustechtips.com/topic/329862-c-fibonacci-nr-help/
