So i downloaded the Razer comms software and i was going to try call in. My problem is that i am using a Xonar DG and the software is required so that it can auto-detect the front panel which is the only place i can plug my headphones into. Why is the razer software not allowing the Xonar software to open? I have never had this problem on Teamspeak, or Skype. Any help is greatly appreciated.
My Timewaster: i5 3570k @ 4.4GHz 1.19v, Asus P8Z77-V, Noctua NH-D14, Sapphire Radeon HD 7850, 16 GB Corsair Vengance, 128GB Samsung 830 SSD, HAF 912, Logitech G710+, G700
https://linustechtips.com/topic/32980-razer-comms-problems/
It's not in the list of audio devices if you click the gear and go to the Audio tab?
"Pardon my French but this is just about the most ignorant blanket statement I've ever read. And though this is the internet, I'm not even exaggerating."
https://linustechtips.com/topic/32980-razer-comms-problems/#findComment-450078
Razer comms works fine on my DG...
CPU: i5 4690K  CPU Cooler: Corsair H100   Motherboard: Gigabyte Z97X UD3H   Memory: G.Skill (2 x 4GB) DDR3-1866   Storage: Samsung 830 Series 128GB 2.5" SSD/Seagate Barracuda 1TB 3.5" 7200RPM   GPU: EVGA GeForce GTX 660 Ti SC 2GB   Case: Cooler Master CM 690 II (Black) ATX Mid Tower   PSU: CORSAIR Enthusiast Series TX650M 650W 80 PLUS BRONZE Certified   Optical Drive: MSI DH-24AAS-17 R DVD/CD Writer   Operating System: Windows 10 Pro (64 bit)
https://linustechtips.com/topic/32980-razer-comms-problems/#findComment-451075
because beta
Normally I'd say this and because Razer. Sorry for the not so serious reply.
Install Gentoo GNU/Linux | "You have been placed on moderator queue. This means that all content you submit will need to be approved by a moderator before it will be shown." | top LEL
Build specs: Corsair 540, i7 2600K @ 4.2Ghz, Asrock z77 extreme4, 16gb DDR3 @1866, 2 x 1TB, GTX 560 ti
Monitors: Asus VG236H, Dell U2713HM Headphones: Koss PortaPro, DT 770 80ohm, AT-AD700 | Steam profile
https://linustechtips.com/topic/32980-razer-comms-problems/#findComment-451777
