Hi guys,
I've recently received 3 Dell Optiplex 960 SFF (Small form factor) pc's. I am setting one up as a media PC and need help adding a graphics card. The PC currently has no graphics card installed and I am running it off the integrated graphics. I want to add a graphics card to play low end games from Steam such as Monaco and Binding of Isaac Rebirth, so nothing very intensive. I also have the problem that the motherboard does not have HDMI so I cannot get sound onto my TV as I am currently using DVI to HDMI adapter. My main issue appears to be the power supply as it is only 235W but it is not upgrade-able as it is a proprietary dell one(but please prove me wrong!). You can get a model of the PC with a graphics card installed (NVIDIA GF 9300) and that has a power draw of 25W so somewhere around there should be okay. Card must be single slot.
Current Specs
Dell Service Tag: 2GFWG4J
CPU: Intel Core 2 Quad @3GHz
Memory: 4096MB DDR2 @ 800MHz
Storage: 500GB WD Blue (Going to add an SSD soon!)
Drive: 8x DVD+/- RW
OS: Ubuntu 14.04.2 LTS
Power Supply: Dell 235W Silver
Dell Support Site
Tech Sheet
My Options
NVIDIA 610
£25.93 + £1.25 + £1.69 = £28.27
NVIDIA recommends 300W power supply
Maximum power draw of 29W
Has an active cooling fan
Cheaper as it is factory refurbished
2GB GDDR3@1000MHz
Core clock@810MHz
A guy I know also has a 610 and it works fine
NVIDIA 720
£34.46
Maximum draw 23W
Includes LP bracket
Will perform better(I assume)
1GB GDDR3@1600MHz
Core clock@797MHz
OR
£41.66 + £1.25 + £1.69 = £44.60
2GB GDDR3@1800MHz
Rest appears to be the same as above
Naturally I probably have not considered all of my options as I have not even looked at AMD yet but NVIDIA cards appear to be better optimised for power which I need considering the power supply constraints
Any opinions, ideas or alternatives will be greatly welcomed and appreciated. I am happy to add more info about the machine if needed.
EDIT: Games at 720p
https://linustechtips.com/topic/329240-help-choosing-low-end-gpu-for-sff/
I can see that you're in/around the UK, where are you?
I might be able to ship you an HD 6570. Its TDP seems to be 44w.
Don't take it personally but I generally don't buy used, I'd rather just buy it new or refurbished in case there are problems(I have had some bad experiences with used in the past). Also I think 44W may be too high unfortunately. Although I just found this: Tom's Hardware
Thoughts?
Thoughts?
Not taken personally. It might be good, but I don't really think of it as having any value. I'd ship it to you as cheaply as I could find and you'd pay me shipping if I were to give it to you.
Sig under construction.
Thanks for the generous offer although I think I'll decline. It's probably more hassle than it is worth for the both of us.
