I currently have 2 fractal fans in the top of my case, they are connected with their voltage reducers to the fan hub. Issue is that without the reducers they are loud as hell, and with them they have a slight wobble to them. Not major but enough I want to fix it. Any solution to this?
https://linustechtips.com/topic/329229-fan-wobbling/
It is not the fan case, but the blades themselves. Also they are put in with the rubber shock mounts.
As long as it doesnt rattle or fall off youre good ;)
Core i7 4820K  |  NH-D14 | Rampage IV Extreme | Asus R9 280X DC2T | 8GB G.Skill TridentX | 120GB Samsung 840 | NZXT H440  |  Be quiet! Dark Power Pro 10 650W
https://linustechtips.com/topic/329229-fan-wobbling/#findComment-4469621
oh
hmmm
What Motherboard are you using?
ASUS P8 Z77-V LK
Yes but it will kill the fans quicker. Seen it burn motors out on room fans so computer ones should be the same, I would think.
https://linustechtips.com/topic/329229-fan-wobbling/#findComment-4469650
Well if they're wobbling that means the bearing is fucked... So they're on the way out anyways.
https://linustechtips.com/topic/329229-fan-wobbling/#findComment-4469679
Damm only got them 2 months ago, then again they have been at full speed for the whole time.
Well inside warranty then. That would be build defect so you should RMA them.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/329229-fan-wobbling/#findComment-4470274
I dunno, I have the same fans and they look like their wobbling a little bit (Might be just the lighting) But as long as they are not making any clicking or buzzing noise I think they are fine.
Build
Mobo: MSI B550 MAG Tomahawk  ||||| Ram: 32 GB GSkill Trident Z RGB ||||| CPU: Ryzen 5800X ||||| GPU: ASUS RTX 3080 TUF OC ||||| Mouse: Logitech G502 ||||| Headset: Sony WH1000XM3 ||||| Keyboard: Logitech G810 Orion Spectrum ||||| Monitors: Acer XG270HU & LG UltraGear 34GP83A-B ||||| AudioStuff: ONKYO DAC HA200 / Audio Techinca ath-ad900x / MXL TEMPO KR USB Condenser Microphone ||||| Storage: 4 TB WD Black --- 2 TB WD Red --- Toshiba 258 GB M.2  ||||| Custom Loop -  Radiators: 3x360 Rad ||||| Case: LianLi O11d XL Black ||||| PSU: Seasonic X series GOLD 1250w
Laptop: Dell XPS 15 9570 4k With a Logitech MX Master
https://linustechtips.com/topic/329229-fan-wobbling/#findComment-4474486
