Download MultiBeast and under Drivers>Audio, check ALC892.
-snip-
You're welcome ;)
Mac drivers are a bitch sometimes
Thanks I have multibeast but when I first ran though it I had no clue what to do for audio. Installing the one you said now, hope it works.
https://linustechtips.com/topic/329225-audio-drivers-for-z77/#findComment-4469590
Heyyo,
Same goes for your GPU. Might need to setup a proper argument on your boot loader for graphics enabler and then download and install the drivers. I found stock vs NVIDIA website drivers made a HUGE difference when trying World of Tanks Mac Wrapper.
Here's my tests of stock drivers Vs NVIDIA proprietary drivers off their website:
http://forum.worldoftanks.com/index.php?/topic/422192-gj-on-the-mac-wrapper-wargaming/
The only odd thing about OSX with NVIDIA proprietary drivers I found? VSYNC didn't work for me lol. My framerate did what it wanted to. :P
Heyyo,
My PC Build: https://pcpartpicker.com/b/sNPscf
My Android Phone: Exodus Android on my OnePlus One 64bit in Sandstone Black in a Ringke Fusion clear & slim protective case
https://linustechtips.com/topic/329225-audio-drivers-for-z77/#findComment-4469952
Heyyo,
When I look for the GPU drivers it only shows for windows
https://linustechtips.com/topic/329225-audio-drivers-for-z77/#findComment-4470827
