Hey guys,
Can you give me some ideads how can i make my PC look nicer?
For now i have all the fans LED, except the top rad fans, and my gpu lights up blue "windforce". It still looks cool, but if i could make it look more like a high tech of the next generation, would be more happy. Specs are in my sig, but i will be adding another GPU for SLI later on, then maybe watercool both of them for the next 2 years...that's a white/black theme build...
I have though of:
Logo,
Toy (inside),
White tube + strips of LEDs.
Intel Core i9-9900K | Asrock Phantom Gaming miniITX Z390 | 32GB GSkill Trident Z DDR4@3600MHz C17 | EVGA RTX 3090 FTW3 Watercooled | Samsung 970 EVO 1TB M.2 SSD | Crucial MX500 2TB SSD | Seasonic Focus Plus Gold 1000W | anidees AI Crystal Cube White V2 | Corsair M95 | Corsair K50 | Beyerdynamic DT770 Pros 250Ohm
https://linustechtips.com/topic/328865-help-me-mod-up-my-case/
I'm more of a: clean, white LED strips, black, majestic, simplistic kinda guy. Not into the flashy lights and colors.
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
https://linustechtips.com/topic/328865-help-me-mod-up-my-case/#findComment-4464143
Well, the Windforce Logo will surely be going, it doesnt match the theme. Just say what else can i add to it?
https://linustechtips.com/topic/328865-help-me-mod-up-my-case/#findComment-4464171
Seeing as you say it is a white and black themed build and you plan on water cooling I would get hard metal piping and make it look black with white LEDs to make it look futuristic. I would do similar throughout the rest of the case. If I seem insane for suggesting that then I thank you. Also there is a modding section so I would also post there for suggestions.
https://linustechtips.com/topic/328865-help-me-mod-up-my-case/#findComment-4464303
Good idea... But with metal becomes hard when you start upgrading, because of the sizes. Ty a lot for suggestion though. This will be a mod or another future generation.
I am looking for external modding...what can i put externally so it can look better...
Hmmm... Look, i found this pic of a model for a solar reactor and i really like the look of it...if i put something cool like that externally...man this hing will look so much awesome... But what will it do...generate electricity..?
Lol sorry im not thinking strait... Thats a PC afterall...not a shuttle...
https://linustechtips.com/topic/328865-help-me-mod-up-my-case/#findComment-4464479
Could you hook up LED Strips via Molex?
I think so... Not sure...
https://linustechtips.com/topic/328865-help-me-mod-up-my-case/#findComment-4464483
How else? Battery's?
I think you hook them to fan connectors...
https://linustechtips.com/topic/328865-help-me-mod-up-my-case/#findComment-4464511
Well, yeah, I think so
https://linustechtips.com/topic/328865-help-me-mod-up-my-case/#findComment-4464564
