So I recently purchased some Audioengine A5+ speakers. http://audioengineusa.com/Store/Powered-Speaker-Systems/A5-plus-B-Powered-Speakers
I wanted to buy a sub to pair with them.
I don't know if all subs work with these speakers or how they'd connect.
I'm running an Asus z87-PRO (V Edition) MOBO http://www.asus.com/Motherboards/Z87PROV_EDITION/
My budget is around $200-300.
Any recommendations? Just want a sub with a lot of glass shattering bass c:
Thanks!
https://linustechtips.com/topic/328824-need-help-choosing-sub/
To hook up a sub I think all you have to do is use the output on the A5+ to the sub input on the sub. But I could be wrong because I dont feel like reading the manual. So you should read your manual. Lots of useful info in those things. As for subs in that price range, the Bic F12 gets good reviews but again, not 100% sure it will work with your A5+
PC Audio Setup = Beyerdynamic DT 770 pro 80 ohm and Sennheiser pc37x (also for xbox) hooked up to Schiit Fulla 3
https://linustechtips.com/topic/328824-need-help-choosing-sub/#findComment-4465067
